![]() | Home > Maintenance & Modifications > Headlight wiring loom upgrade |
| Petronius4 Member Since: 07 Oct 2015 Location: Somerset Posts: 94
Hi, does anyone know if the wiring for headlights has changed recently? I'm trying to find out if the most recent Defenders actually have a relay in the lighting circuit or are still run straight through the headlight switch.
I've read about installing boomslang (and others) wiring looms to reduce the load on the headlight switch but am unsure if my 2015 D90 would benefit from this. Thanks chaps. ------------------------------- 👲🏻 1986 ex-Military 90 NAD 2.5 Soft Top. Sold 🇬🇧 2015 Defender 90 - Ripon Landrover Heritage 006 |
| Pjembe Member Since: 21 Jul 2015 Location: Newbiggin by the Sea Posts: 143
Hi Petronius I recently fitted a boomslang loom to my MY15 110. The reason for doing so was not so much to protect the light switch But to improve the headlamp light output. Not being a techie Im not sure whether there is a relay between the switch and light circuit, so fitting a loom for that purpose I am not sure about. Whate I do know is that there is a marked difference in the road illumination which is further improved by fitting some upgraded headlamp bulbs.
It may not answer your question directly, but it may help your decision. |
| Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3472
No major changes to the headlamp circuit so fitting a loom and relay/s should prove to be of benefit. Steve.
Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
| All times are GMT |
