Home > Puma (Tdci) > Drive Flanges
Page 2 of 3 <123>
ericvv
Post #505704 18th Feb 2016 4:55am
Avion8
Australia 2015 Defender 90 Puma 2.2 Heritage Edition SW Grasmere Green
Hi ericvv, It would seem so, except yours have a blue dot, whilst mine are the green dot special. Mr. Green How have your held up? I had to replace mine on the 110 TD5 @ 320000kms, and went with the HD flanges & shafts all round.
Post #505705 18th Feb 2016 4:59am
ericvv
Avion, suggest you ask me again when I will reach 320.000 KM, which at the annual mileage I'm doing now will be in 50 years or so. Laughing
Seriously, nothing bad to say about mine sofar.
Except, I am a bit confused about what is meant by "flanges" here, see someone also mentioned "half shafts" in his post. Well, my rear half shafts were replaced by JLR under the extended warranty, at about 65.000 KM it must have been. I had been complaining about a clunk when changing gears, and they traced it back to the rear halfshafts at the time. Now all fine, but barely 13.000 KM further with the new ones.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #505707 18th Feb 2016 5:08am
Sadi
Namibia 2016 Defender 110 Puma 2.2 Heritage Edition SW Grasmere Green
At the local dealership - the last 110 SW on the floor: the rear has the "thin" Dicovery setup as per Shaggydog's reply, and the fronts the standard 2-piece setup as per Avion and Eric replies.
When pointed out to the sales guy - he immediately recognized the rears as the old "Discovery" setup.
On the last runout models - maybe there was a scarcity of some parts and an abundance of others that could be safely swapped/used for the same purpose.
Must say - makes for an "unique" vehicle - the different "flanges" front & rear ...
(A colleague of mine is interested in buying the vehicle - may be able to snap the necessary pics then)
Post #505710 18th Feb 2016 5:31am
Avion8
Eric
Hi ericvv, Seems you have already had your half shafts replaced & I would imagine they would have replaced the flanges at the same time, as both wear & cause that clunking. Seems the HD route is the only way of preventing this, although I note from your photo that there seems to have been a liberal supply of copper grease applied to the flange & presumably the splines on the half shafts. This may well help slow the wear down.
As Sadi mentioned in the last post he has seen a 110 SW with the one piece flange half shaft on the back & seperate flange shaft set up on the front, so must have run out of flanges!
Post #505714 18th Feb 2016 7:34am
dailysleaze
When I did the factory tour in November I saw that there were one piece drive flanges fitted to 110 vehicles' rear axles. Not the same as the older rounded 90 versions, but a squarer look:
Post #506009 18th Feb 2016 11:26pm
shaggydog
The only very vague reason I think they may have done this was to mimic the series 1 setup which had the 2 piece arrangement on the front and a different one piece set up on the rear.
Personally, I am of the opinion that it is better to have the 2 part setup as it will wear out your drive flange, then for under �20 you can replace it and off you go again, rather than having to change the whole shaft - admittedly a much less common occurrence.
By using HD Drive Flanges your moving the wear away from the drive flange and onto the Half Shaft which is much more expensive to replace.
Just my 2p worth Smile Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #506112 19th Feb 2016 2:03pm
ericvv
Eric
Avion, the copper grease in my picture was done on my request each time my dealer change from winter to summer wheels and back, so it was just on the outside of the hubs. So when dealer replaced the half shafts, I have no idea if they put any grease in really.
By the way, I now am not using copper grease any more for the wheels, but use ceramic grease instead which is void of any metals content, and which I think is a better grease for where alloy wheels contact steel hubs in the summer. Use it year round now, so also for the HD Wolf steel winter wheels. Thumbs Up
The stuff below. Eric
Post #506144 19th Feb 2016 3:54pm
Devon-Rover
A bit of Thread Exhumation.
Now Microcat has caught up it tells that the Rear shafts when from two piece back to one piece on VIN GA481822
Part number RH LR072976
LH LR072977
And If you have the earlier versions it will supersede to those numbers.
Post #518845 29th Mar 2016 2:39pm
Cetane
United Kingdom 2010 Defender 110 Puma 2.4 HT Galway Green
Ive just ordered 2 new rear halfshafts. They have indeed changed to one piece. Cheaper too.
Will post some pics when they arrive.
Post #519993 1st Apr 2016 3:28pm
Fatboy Slim
Wales
The one piece setup is far superior in every way. Great news they've gone back to it. Save me retrofitting them now Laughing
Post #520026 1st Apr 2016 4:40pm
tuesdayfox
2013 Defender 110 Puma 2.2 SW Zambezi Silver
are the one piece shaft easy to purchase?
Post #520792 4th Apr 2016 11:44am
Cetane
Yep.
They superceed the spline and flange type. Give the dealer your VIN and they should be listed against your vehicle.
Post #520804 4th Apr 2016 12:07pm
Cetane
Photos as promised
No more worn splines! Thumbs Up
Post #521218 5th Apr 2016 5:50pm
shaggydog
Out of interest how many splines do they have?
Look good though Thumbs Up Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #521220 5th Apr 2016 5:56pm
Page 2 of 3 <123>
