Home > Maintenance & Modifications > Snorkel help.
dumptruckface
England 2012 Defender 110 Puma 2.2 XS DCPU Orkney Grey
Snorkel help.
So i have a raptor 4x4 snorkel to fit, looking at it its pretty straight forward until you take a closer look at the rubber washers, anyone have an idea of how it is supposed to fit, if these washers are to go through the wing its going to be four very large holes than need to be drilled.
Raptor 4x4 dont know! and they are going to call up the factory in italy...which doesn't help me right now!
Post #505214 16th Feb 2016 5:32pm
dumptruckface
ok so i took the bull by the horns!, if the manufacturer doesn't know how it should be fitted and what configuration the rubber washers should be in then there is not much hope, came to a decision and fitted it.......... not overly impressed with the lack of instructions but pleased with the product, and looks great.
Post #505397 17th Feb 2016 8:59am
DonH2000
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Santorini Black
Any pictures?? Cheers Don.
Post #505409 17th Feb 2016 9:41am
dumptruckface
worryingly the manufacturer got back to me with some pictures of the snorkel and how to fit it.... and its totally different to the one i have fitted!! with a new bit of pipework for the air intake pipe, rather than the one i have fitted just pulls tight onto the wing? .... and mine has external bolts on the front which dont look as good as the hidden bolts on the safari and the ones he sent me pictures of Sad but it still looks good .. pics to follow.
Post #505731 18th Feb 2016 9:51am
dumptruckface
bit of black paint on the stainless bolts today and the job will be finished..... oh that and a final check to be sure its totally sealed up and water tight tot he air box. Smile
Post #505733 18th Feb 2016 9:57am
Does that snorkel kit replace the OEM dirty air ducting from the inside of the wing to the air filter box?
Post #505779 18th Feb 2016 12:36pm
dumptruckface
No it does not, it basically clamps to the outside of the wing, with a seal (i have added more sealant to be sure its water tight from outside) your thoughts?
Post #505785 18th Feb 2016 12:52pm
You'll need to look closely at the OEM ducting then - it's far from airtight with only plastic slip joints.
Post #505786 18th Feb 2016 12:55pm
