Home > Td5 > Help with random tiny pipe FPR on new TD5 lump
Welkman
Hi All,
My FPR on the new engine has a small pipe (must be 1.5-2mm ID) coming off the back where my genuine one fitted to the old engine does not.
Is this some kind of leak/spill pipe? Should it be connected to anything. It is not one of the main fuel pipes, much smaller.
James
Post #505439 17th Feb 2016 10:47am
dorsetsmith
it is vent pipe from the back fuel pressure regulator diaphragm
the old engine fuel pressure regulator will have small hole instead works same way
Post #505466 17th Feb 2016 1:06pm
Welkman
Thanks mate, that has put my mind at rest !
Post #505468 17th Feb 2016 1:17pm
grumpy old git
I've seen a small diameter piece of tube fitted to that pipe to direct any leaks below the starter motor as it can be a good way to chuff it up if it leaks.....
Post #505561 17th Feb 2016 7:45pm
Hufflepuff
Excellent, power of the search tells me I don't need to worry about the same thing Smile I was wondering if the old one has snapped off or something.
That bottom knut is a sod to get to, no way of getting my torque wrench on there, was barely able to get a flexible bar onto it. Still a run round the block and there's no massive flood of fuel coming out, so I guess its acceptably tight.
Did anyone else's fuel pump sound different (with the engine off, ignition on) after going through the bleed procedure?
Post #511375 6th Mar 2016 6:12pm
