Home > Maintenance & Modifications > Door catches
excossack
Door catches
On the passenger side door there is a plastic cover/roller over the part of the catch that strikes the door catch, whereas on the drivers side there is not.
Should there be? and what's its purpose? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #505157 16th Feb 2016 2:56pm
jimbob7
Anti theft device?? Pov.spec,ftw. 2006, 110,TD5.
Post #505162 16th Feb 2016 3:06pm
gilarion
Both driver and passenger side door catches have the white roller fitted on the TDCi, however, on the 200Tdi the roller on the catch is black. looks like the roller thing is made of nylon.. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #505165 16th Feb 2016 3:15pm
excossack
The roller on one door is a dark grey/black colour. 1999 Defender TD5 110
Regards
John M0VAZ
Post #505166 16th Feb 2016 3:19pm
sgilmour
United Kingdom 1994 Defender 90 300 Tdi CSW Arles Blue
On my 300TDi I had the driver side with no bush on the striker (assuming this is the part you mean?) and the latch had actually created a cut out through the metal part of the striker as it had been used be the previous owner who obviously didn't care Evil or Very Mad
The passenger side had the same but a tiny sliver left of the bush (soon broke) but with the same groove where the door had just been slammed through the striker by the previous owner. Some peoples attitude towards car care truly baffles me! Banging Head
I've replaced both with new strikers (with white bushes/rollers) included and both doors shut much better. I believe their purpose is to protect the door catch from being damaged when closing the door onto the striker plate. Break the cheap plastic bit and replace the striker for a few quid instead of the entire latching mechanism. Thumbs Up
Post #505172 16th Feb 2016 3:40pm
The sleeve thingy is intended to reduce the likelyhood of the door rattling ( Rolling with laughter ) and to prevent wear in the other parts by being a sort of sacrificial thing. Various colours have been used over the years but the colour is of no significance.
What you will find is that as the plastic sleeve wears it becomes increasingly difficult to close the door (it latches onto its anti-burst catch rather than fully shut). If you rotate the plastic sleeve through 180 degrees it will shut properly again, but only for a while.
Most aftermarket strikers don't have the sleeve, and work much better and for longer as a result.
It is possible when they wear to adjust the striker again, but if the sleev then rotates back to an unworn orientation you will have trouble shutting the door again!
All in all it isn't one of the greatest design features of the Defender.
Post #505203 16th Feb 2016 5:01pm
excossack
I have ordered a new door catch with the added white plastic roller and new screws.
This might explain why the drivers door is always a PITA to close as there is no roller 1999 Defender TD5 110
Regards
John M0VAZ
Post #505399 17th Feb 2016 9:21am
When mine wore out I bought a set of "X-Trouser" strikers from X Eng (now sold via Foundry 4x4) specifically because they didn't have the plastic sleeve!
X-Trouser
Post #505431 17th Feb 2016 10:38am
Cupboard
Is there supposed to be an equivalent on the back door? Mine needs a firm shove to close, too soft and it doesn't fully close, too hard and it bounces back and doesn't fully close.
Post #505478 17th Feb 2016 1:47pm
Screbble
Re: Door catches
Good man for pointing this out excossack - just noticed I have one on the drivers but not on the passenger!
Just ordered a bearmach pair for under a tenner.
Saving up for the X-eng, but in the meantime I should shortly be able to close the passenger door a little easier! Thumbs Up
Post #506708 21st Feb 2016 4:49pm
excossack
I am yet to fit mine, so will report back once done. Hopefully the drivers door will be easier to shut.
Good luck! 1999 Defender TD5 110
Regards
John M0VAZ
Post #506717 21st Feb 2016 5:03pm
Screbble
New striker plate fitted to the passenger side in about 3 minutes and what a difference. No more struggling and now a much more firm 'clunk.'
Best £4.97 I've spent in a long while Thumbs Up
I wouldn't have noticed if I hadn't picked up on this thread - thanks guys Bow down
Post #508310 26th Feb 2016 12:17am
rallysteve
I have the x-eng ones and dont seem worth the money. Still wreck pretty much every pair of trousers on them and the allen key headed bolt in the end is always coming loose.
Post #508340 26th Feb 2016 8:00am
Screbble
Sorry to hear that Steve, but thanks for the heads up Thumbs Up
I suppose it's always better to learn from other people's mistakes. Neutral
Having said all that, I haven't had the trouser problem (ooh er missus), but I have had the seat belt and closing issues.
I've hopefully resolved at least one Thumbs Up
Post #508343 26th Feb 2016 8:19am
excossack
Replaced the drivers side door catch and I can now shut the door without having to slam the door. 1999 Defender TD5 110
Regards
John M0VAZ
Post #515506 17th Mar 2016 9:42pm
