Home > Technical > Tow bar wiring
nmj
England 2016 Defender 90 Puma 2.2 Adventure Corris Grey
Tow bar wiring
having fitted the rear step and tow ball to my Adventure 90 can anyone advise if there is a plug and play wiring kit i can buy for using when towing ? , i won't be needing anything caravan friendly as will purely be flat bed and enclosed trailers , many thanks in advance for any help/suggestions Thumbs Up
Post #504535 14th Feb 2016 11:51am
discomog
I suppose the first question is do you need 7 pin or 13 pin? When I ordered my 90SW I asked for 13 pin electrics but guess what, it was delivered with 7 pin. The auto electrician at my local dealer was not impressed as he had to convert and it was not as straight forward as he imagined. I'm sure someone on here will know if its a straight plug and play or not. Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #504560 14th Feb 2016 12:31pm
nmj
Re: Tow bar wiring
i think i will be wanting 13 pin as i think any trailers that i intend to use will be modern with reverse lights etc , unless i am on the wrong track with that train of thought !
Post #504578 14th Feb 2016 1:44pm
mse
all plug and play - dead simple connection under the rear spray shield in the arch:
http://www.duckworthparts.co.uk/landrover/...rying.html Mike
Post #504620 14th Feb 2016 5:14pm
nmj
many thanks Mike , appreciate your advice , will get onto their website and get it ordered Thumbs Up
Post #504624 14th Feb 2016 5:18pm
mse
No problem - its surprisingly simple on all the LR's but the defender is by far the easiest! Mike
Post #504626 14th Feb 2016 5:21pm
nmj
that suits me then !! and re mounting the plug , fit it in the recess in the rear cross member rather than underneath join a bracket ? , after looking at various photos of the above it does look neat , rgds
Post #504628 14th Feb 2016 5:27pm
apt100
United Kingdom 2016 Defender 90 Puma 2.2 XS CSW Aintree Green
13 pin needs an extra connection into battery box and on the LR kit picks up a connection off the back off of one of the switches in the dash. Try a search... wiring details have been posted several times. Or track down the LR kit number then go onto Topix for the wiring instructions Thumbs Up
edit quick search shows this which is for 110. Will give you an idea of what is generally involved... http://www.defender2.net/forum/topic13747.html?
Post #504630 14th Feb 2016 5:31pm
jeffersj
United Kingdom 1996 Defender 90 300 Tdi HT Bronze Green
I think you can also buy a converter to 13 pin for when needed, save altering wiring. Jeff
Ex 1968 Series 2A
Ex 90 TD5
Ex D3
Ex D4
Post #504632 14th Feb 2016 5:35pm
PaulMc
The wiring that runs to the battery box and dash, is for the caravan functions - fridge, etc...
If you don't need these - then, you can just use the connections in the 9-way connector under the wheelarch.
This connector has all of the road lighting, including reversing lights, and a permanent live.
. Paul.
Post #504634 14th Feb 2016 5:46pm
nmj
excellent , many thanks Guys Thumbs Up
Post #504660 14th Feb 2016 7:01pm
apt100
Note this is definitely a question and not a statement... will it cause a problem at MOT if not all pins are correctly wired and functioning?
I though I had read that now 13pin sockets are part of MOT?
Post #504667 14th Feb 2016 7:12pm
discomog
I seem to recall that the MOT Test was updated in 2012 to include towing electrics. Here is a quick quote from an item in a caravan magazine-
There will be a basic security/damage check of 7-pin sockets, but 13-pin sockets will be subject to a full electrical connectivity check and incorrectly connected or inoperative circuits will result in MOT failure.
Best to check with your local MOT Station or VOSA Defender 90XS SW
Morgan Plus 8
Post #504673 14th Feb 2016 7:25pm
Martin
Site Admin
The branch which goes forward to the battery box is for the ignition switched feed for 13 pin electrics. This branch is still not fitted on my XS Embarassed
Quite why LR didnt provide the required ignition supply at the back as part of the other tow electric connector I don't know Rolling Eyes  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #504687 14th Feb 2016 8:07pm
mse
I understood if you fitted the 13pin to 7 pin converter they dont test it because they have to test the car as presented and 7 pins do not get checked. Thumbs Up... i just googled it and it seems like im not the only one who has thought about it.
Fortunately i dont have MOT's Mike
Post #504688 14th Feb 2016 8:09pm
