Home > Series Land Rovers > Series 3 2.25 petrol blue smoke
Cheshire110
I know this isn't really a series forum, but figured it's worth an ask.
Our series three tends to produce a (fairly significant) puff of blue smoke when you pull away having been idling (ie at lights).
To me this indicated oil passing the piston rings and being burned off when you pull away?
Also it's never been (as far as I know) altered to run on leaded fuel, is this even a problem on a 1983? I know some cars just don't care.
It's only done 24,000 miles and very good nick otherwise.
Appreciate any advice,
Cheers,
David Cheers, David
Post #504033 12th Feb 2016 7:57pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
It could be worn piston rings, have you taken the plugs out and inspected them? You can tell a lot by the state of them.
Better pic added 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #504034 12th Feb 2016 8:00pm
Cheshire110
That was my thoughts, good to know I can make a bit of sense sometimes! Not done anything yet. Cheers, David
Post #504036 12th Feb 2016 8:04pm
It could also be the valve guide oil seals (O rings) in need of replacement.
Post #504046 12th Feb 2016 8:25pm
Cheshire110
Woops wrong thread!
Thanks for the advice Smile Cheers, David
Post #504089 12th Feb 2016 10:00pm
Gonarezhou
South Africa 2015 Defender 110 Puma 2.2 SW Alaska White
Never had one that doesn"t ! And that is with some many many years of experience. It is normal ........ Black smoke is a different story1
Post #504096 12th Feb 2016 10:07pm
Cheshire110
Yep not really worried about it at all.
Any thoughts on unleaded conversion? At the moment we use additive but it's a bit of a pain, interested to know if a conversion's necessary. Cheers, David
Post #504099 12th Feb 2016 10:09pm
Gonarezhou
David I ran an old Series III for two years on Unleaded 101 Octane Avgas in the Zambezi valley of Zimbabwe....worked hard and actually never missed a beat even when my Cruiser electrics were causing me nightmares!
Post #504102 12th Feb 2016 10:15pm
Gonarezhou
Actually I don't as many think the blue smoke comes from oil passing through the rings (and I have reasons for this) my own speculation is that the oil ingresses through the valves by seeping in through the valve stem seals....just my own thought.
Post #504107 12th Feb 2016 10:20pm
dorsetsmith
http://www.turnerengineering.co.uk/acatalog/2.25_Petrol.html at bottem of the page unleaded converion heads inp and metic
Post #504109 12th Feb 2016 10:24pm
Trebro
United Kingdom 2009 Defender 130 Puma 2.4 HCPU Stornoway Grey
I had oil coming up the head and being blown through the rocker cover breather back into the inlet manifold. Head gasket had blown between cylinders and subsequently exhaust n inlet valves were burnt.
Maybe best to try a compression test first then work from there?
Post #504138 12th Feb 2016 11:14pm
Trebro
I tried additive for a while in my 5 bearing engine, then read that it wasn't required in the 5 bearing engines, I noticed no difference driving without additive, ironically I found using 97 Ron petrol made it run poorly.
Post #504141 12th Feb 2016 11:18pm
