Home > Puma (Tdci) > Difficult reverse, second and fourth gear
dantastic
I have a 2.2, build some time in 2015.
I have never driven any other pumas so I don't know what's normal and what's not.
I drove a very nice TD5 for years and my old R380 was vastly superior in terms of gear change quality.
The problem is the gear shifter is very stiff. I have to force it in every direction. Not forcing any gears but the actual gear shifter itself. So for instance is stationary, clutch down, select second, in to neutral and select second again. (An operation which should be very smooth) and I have to use more force than comfortable.
It gets better when warm but not much. The gear selector action between 1-2-1 gets better but the shifter stick is still just as stiff.
Same with reverse then, have to push really hard to get it it.
1 3 5 are ok but R 2 4 are pretty bad. R is the worst, then 2 then 4 and 6 isn't too bad.
Is this normal on these or should I consult my local dealership?
Post #503977 12th Feb 2016 5:40pm
Ryderoo
England 2015 Defender 90 Puma 2.2 HT Santorini Black
In Warranty, take back to Stealers, no question. Cheers Simon
I can explain it to you, but I can't understand it for you
1990 110 TD5 county, my first Land Rover - gone
2012 Discovery 4 XS SDV6 - gone
2014 Discovery 4 XS SDV6 - gone
2015 Evoque SD4 dynamic - Wife’s - gone
2015 Urban Truck 90 XS Santorini Black Hard Top - Reluctantly gone
2020 Discovery 5 Eiger Grey 3.0 SE - gone March 24
2021 Defender S D250 Santorini Black 110 HT - gone March 24
2023 Evoque P300e SE wife’s current vehicle
Post #503983 12th Feb 2016 5:55pm
An MT82 box in good working order should have a better action than an R380 in good working order (the R380 has always been second rate). There's something wrong, so invite the dealer to put it right.
Post #504022 12th Feb 2016 7:17pm
dantastic
Ok, so the M82 should be lighter and smoother than the R380?
Not the case in my case. My old R380 was smooth and light. This one is heavy and clunky.
Post #504027 12th Feb 2016 7:34pm
Which is why I think there's something wrong with it!
I've not yet met an R380 which is as light, smooth, and precise as my Puma.
Post #504048 12th Feb 2016 8:28pm
