![]() | Home > In Car Electronics > Tapping into the interior light circuit.... HELP! |
| mcma1 Member Since: 16 Oct 2012 Location: Northern Ireland Posts: 2947
Needles not moving either? Andy
2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
| Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6735
Can you fill in your Defender profile
You have disturbed the permanent 12V supply to the cluster, it's fed from the same fuse as the interior lighting (Fuse 30, 10A). Sounds like a faulty splice/joint where you have tapped into the Purple/Brown to feed your new lights. Where did you cut the purple/brown? 1988 90 Td5 NAS soft top
2015 D90 XS SW |
Explain the the profile comment please....
I gave everything a good run over and disconnected and re connected and all appear ok now! As you say it must have been a bad connection, I have a couple I still need to solder up so likely it's one of them! Thanks Andy Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
The drop-downs for model/variant/colour/engine etc
Glad its OK 1988 90 Td5 NAS soft top
2015 D90 XS SW |
| All times are GMT |
