![]() | Home > Maintenance & Modifications > Burning smell |
| Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3472
Not a known issue. Are you sure you are always releasing the transmission [hand] brake fully? Steve.
Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
| JOE_130 Member Since: 26 Nov 2014 Location: Chelmsford Posts: 105
Is it a sulfurous smell? Mileage intervals of around 200 would be the DPF regen'ing, I get nasty wafts of it occasionally when stationary after a cruise. On a separate note mine has a "hot" smell occasionally with the heater on but I wouldn't go so far as to say it was a burning smell. Mines got around 6k on the clock now.
| Gareth Member Since: 12 Dec 2011 Location: Woodford Posts: 1142
The DPF gets very hot when its regenerating. 2021 Defender 110 X-Dynamic HSE D300 MHEV
1966 S2a 109 aka Betsy |
| Wild Card 90 Member Since: 03 Dec 2014 Location: Gerlingen Posts: 1060
Has it had an underseal treatment done at the dealer? It is very easy for some oily wax paint treatment to get onto the exhaust system and slowly burn off.
2008 Td4 90 SW, 2012 2.2 90 SW, 2" raised Trailmaster/Terrafirma Heavy Track Raids, 255 MTīs, Recaro CSīs, anorak, wellingtons |
| Cupboard Member Since: 21 Mar 2014 Location: Suffolk Posts: 2971
When you say you don't think you ride the clutch, if your foot isn't on the pedal you're not riding the clutch and if your foot is on the pedal once you've changed gear take it off
You don't actually need the clutch to change gear, you get much smoother gear changes without by just matching the revs. |
| APK Member Since: 13 Jan 2015 Location: London Posts: 255
Yes, but I will double check from now on. Thanks! |
Will look out for this. Wish I could describe it better |
Yes, Zagato did a great job with it a few weeks ago. Doesn't explain the episode soon after picking it up from the dealer though. Last edited by APK on 12th Feb 2016 9:18am. Edited 1 time in total |
I'm on a 150 mile trip both ways tomorrow. Will be very mindful of all the comments and report back if any issues. Thank you very much for everyones help/advice! |
| chipmunk Member Since: 10 May 2012 Location: Kelso Posts: 264
I've had this smell periodically just after I got the car. Was quite alarming as it isn't a clutch or brake smell, or anything else recogniseable. I had never had this smell with previous Land Rovers. Occurs after a bit of a run out but not every time so recycle DPF sounds very plausible.
Hasn't happened for a while now. |
Thanks for that.
I took it for an hours run in London traffic today and did not get it. Its just happened twice so far and as you said very difficult to describe. |
| gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5141
Sometimes I get a burning smell, worked out it was the heater sucking in air from the outside when someone was having a bonfire or burning rubbish.
The other day I was behind a car towing a caravan up the steep incline at the beginning of the Llanrwst road in North Wales, the car was struggling with the weight of the caravan up the hill and you could smell the clutch burning, which again the heater was sucking in, took about five minutes with the windows open to get rid of the smell. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at.. http://www.youtube.com/user/conwy1 |
I'm very mindful of not riding the clutch. Foot is not on the peddle etc. I do find it difficult to avoid 'clutch balancing' on first gear in slow moving traffic though (esp on a slope). Also, in reverse gear I have no choice but to clutch balance. Is there something I am missing here? How do you change gear without the clutch? This is embarrassing, I feel like a kid learning to drive all over again! |
Thanks. Is this even with the lever on air circulation vs fresh air? I will check my setting once again. |
| All times are GMT |
