![]() | Home > Technical > Rear brake problem - any ideas |
| williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441
Think I would go for a set of discs and recon or new calipers
| red squirrel Member Since: 10 Feb 2016 Location: Perth & Kinross Posts: 2
Thanks for the idea...it had new calipers and discs fitted in July last year so am assuming they are not the cause.
| Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3472
I'd get it on a brake tester. Steve.
Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
| miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1791
Or jack a rear wheel up, have an assistant apply the brakes and see if you can turn the wheel. Often you have to apply the brakes really hard to get any decent braking force out the rears. Especially when unladen, the bias valve will reduce the braking force to the rears.
| Supacat Member Since: 16 Oct 2012 Location: West Yorkshire Posts: 11018
Without diagnosing the root cause? Seems an expensive and haphazard way to go. Have a look at the rear pads on both sides of the caliper, are they equally worn? Also, are the inside faces of the rear discs as equally rust stained as the outer faces? Do you have any old pads? If you can get a set, swap them out and have someone operate the foot pedal whilst you watch the caliper to see if the pistons have a full free range of movement. You can use a block of wood if you have no old pads - it's just something to limit the piston movement range and stop them coming out too far or falling out completely. Try to see if you can push them back in fully by hand, it should not be too easy but equally it should feel smooth and consistent. Your issue could also be with the fluid getting to the caliper. Is the condition of the flexible hoses good, no leaks, bleed nipple clean and air tight? |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18050
The pistons could be sticking in the rear calipers. Try pushing the pistons back in the bores and assess how easily they move.
| All times are GMT |
