Home > Td5 > Can I use Pre1986 brake pads on newer model?
travis818
Singapore 2001 Defender 90 Td5 SW Barolo Black
Hi all,
I've ordered a set of defender front brake pads wrongly and received the STC2956 (for pre 1986 Defenders using STC8573 retaining pins and clips).
I'm wondering if it fits my MY2001 ABS model which uses SFP000260 brake pads and STC8574 retaining pins.
Apart from how the brake pads are being secured, do different MY calipers differ?
Post #502976 10th Feb 2016 4:21am
ibexman
Why woul you want to muck around with something your life depends on get correct parts Whistle
Post #502997 10th Feb 2016 8:48am
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
Return the pads and get the correct ones Thumbs Up 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #503001 10th Feb 2016 9:04am
travis818
Have already placed order for the correct set but wondering if they are both compatible just with a different pin to hold them down.
Unfortunately, air freight cost is more than the item cost so returning is not an option.
Post #503010 10th Feb 2016 10:09am
Mo Murphy
Best thing to do would be to remove one of your existing pads and physically compare with the new.
I'm pretty sure you'll be ok with rears but I'm not so sure about the front pads as I think they may have changed the pad when they changed to the larger diameter caliper piston.
HTH
50 Shades of Pennine Grey
Post #503363 11th Feb 2016 8:49am
