Home > In Car Electronics > The Puma dip/dim relay myth???????
Shiltmeister
Spain 2009 Defender 110 Puma 2.4 SW Alaska White
Hi all
I'm having issues with a new Boomslang headlight loom fitted to a 2009 Puma. No full beam of flash since installation. Replaced cheap relays on loom for better quality ones but no help.
I've heard rumours about needing to bypass the existing dip/dim relay to solve this problem. Does it exist or is it just a myth? Looked everywhere for this answer.
MOT next week so need to solve it.
Please help!! Big Cry Big Cry 2009 Puma 110 SW
Post #502265 8th Feb 2016 8:10pm
Yes it does, in the relay/fuse housing under the column. The easiest way to disable the dimdip is to unplug the connector for the series resistor, located under the offside wing top near the aerial. All you need do is unplug the connector.
Post #502294 8th Feb 2016 8:36pm
Shiltmeister
Thanks for the reply. On my LHD Puma this relay doesn't exist under the steering column. The big pink one is the wiper relay.I've hunted all possible alternatives.
Is the resistor easy to locate? I hunted all around both wings and around where the arial is. This is starting to get annoying 2009 Puma 110 SW
Post #502333 8th Feb 2016 9:23pm
Aha, left hooker, missed that! Pretty sure you won't have dim dip, since it was conceived by idiot British bureaucrats and inflicted only on us.
You presumably know if you had it before you changed the loom and lights.
Post #502370 8th Feb 2016 10:29pm
Alien
Australia
Re: The Puma dip/dim relay myth???????
Shiltmeister wrote:
Hi all
If it's only happened since fitting the harness that's where I'd be looking.
Check for an earth wire not being connect that is for the full beam relay.
Also check if there is a separate power supply of the same relay, maybe it's not connected or has a blown/missing fuse.
A later thought...
Is the blue light on the instrument panel lighting up?
This should be working if the headlamp switch is good. Cheers,
Kyle.
Post #502536 9th Feb 2016 10:34am
theorangebandit
This may seem like a stupid question but ... Have you checked the high beam fuses ? These are easily blown when fitting things to the headlights if the ignition is left on. They are each fused individually left and right
Post #502593 9th Feb 2016 12:57pm
Shiltmeister
Alien wrote:
Shiltmeister wrote:
Hi all
A later thought...
Yeah the full beam blue light glows on the dash and the indicator stalk switch gear is new. Hence why I'm fitting the new loom as I kept melting them.
I will check the relays again in the loom to be sure.
Thanks 2009 Puma 110 SW
Post #502719 9th Feb 2016 5:33pm
Shiltmeister
Thanks but yes it was first think I checked. I will not let this defeat me! 2009 Puma 110 SW
Post #502720 9th Feb 2016 5:35pm
Shiltmeister
FIXED!!!
Thank the lord. Rechecked all the connections in the relay holders and after a bit of tugging of everything the +ve crossover between the two relays slid out with a broken crimp on the end.
Thanks for your inputs. 2009 Puma 110 SW
Post #502760 9th Feb 2016 6:56pm
Alien
Australia
Good to see it's sorted Thumbs Up Cheers,
Kyle.
Post #503012 10th Feb 2016 10:20am
