![]() | Home > Puma (Tdci) > Another oil question - has anyone ever had problems with DPF |
| Jukathy Member Since: 25 Jan 2015 Location: Berlin Posts: 170
I have experienced problems although I suppose the retailer used the correct oil as listed on invoice.
Car has been towed to retailer. Juli. |
| Discowill Member Since: 06 Apr 2014 Location: Uk Posts: 34 |
Ok thanks - on my invoice it simply said castrol 5w-30.
Technically correct I guess - although the wrong spec. But to be honest I do wonder if it is such a big deal unless you are doing a lot of short journeys. I see BMW recommend a5/b5 for their diesels, although the dpf will be a different design of course. Will |
That's right. A4/B5 is high SAPS - C1 is low SAPS.
A high SAPS oil causes more soot i.e. shorter life cycles for the DPF. A low SAPS is worthwile for your DPF. Juli. |
| All times are GMT |
