Home > In Car Electronics > Tapping into the interior light circuit.... HELP!
Page 2 of 4 <1234>
MCMA1 - Yes, it's isolated anyway from the lighting circuit. Will be fine.
It's only the door switches being used as a switch so they aren't taking any load.
Only issue I can think of is you'll likely need to wire to both front door switches otherwise it'll only work for one door only.
(Depends as I mentioned before if the earth for them is a common shared earth or indipendant. Easy to find out by continuity checking.)
Same for the rear but I'm assuming your not worried about the rear.
Basically your diagram is completely indipendant of the lighting and you are only utilising the door switches exactly what they are for.
So yes, all good. Go for it. Thumbs Up
Post #501810 7th Feb 2016 8:19pm
mcma1
Ah just realised my mistake!! Yes I want these to come on if any door is opened, as there are 5 door switches in the 110 and only 2 interior lights, does that not suggest the 5 switched grounds come together somewhere?? It would save me having to tap into 4 switches if I could tap in somewhere else common to all the doors?? What do you think? Andy
2014 Fuji 110 SW LS3
https://www.defender2.net/forum/post751233.html#751233
2014 Corris 110 SW
http://www.defender2.net/forum/topic40056.html
My old Xtech 90 build..
http://www.defender2.net/forum/topic15681.html
LS3 V8 build...
http://www.defender2.net/forum/topic49051.html
Post #501820 7th Feb 2016 8:30pm
Cupboard
custom90steve wrote:
^^^ This is why I stuck to the light fittings only.
Providing you don't exceed the consumption of draw then you can do no wrong.
I tried to match the current draw as much as I could too but isn't easy as LED's draw so little power.
I want to do some work with mine but it doesn't stop raining so....
No need to worry about too low a draw Thumbs Up
Post #501824 7th Feb 2016 8:35pm
True, but the dimming will be faster the lower you go.
If your not worried about that then there's no need to worry about it.
Currently I'm drawing about 600mA and works well.
Post #501829 7th Feb 2016 8:43pm
Cupboard
https://onedrive.live.com/?authkey=!ALkeja...9C85C7C171
Yes, they do all come together.
Up shot being that it doesn't matter which one you use because they're all connected together.
But please, please be careful!
I do not know what voltage the 10AS works at internally. It is entirely possible that it's 5V. I do not know how robust it's internal circuitry is, it's possibly great it's possibly not. If it's designed in the most cost effective way and uses a 5V pullup and logic, putting 12V to the input may well kill it.
There are three possible states for a digital input. High, low and floating. If an input is floating then depending on which way the wind is blowing or the sun is shining or which way you've rubbed your Defender the input could be on or off and that's not very helpful. So in input needs to be pulled to either on or off. Now we know that when you open a door it connects the circuit to ground, so therefore the default doors closed state would be floating with no other influence. Because we can't have a floating input in to the 10AS, there will be something in the 10AS pulling it to whatever voltage the 10AS wants on its input to register.
Say that's 5V. There will be a 5V power supply in the 10AS, run that through a 10k resistor and all the time the doors are shut you'll get 5V at the input (through the resistor) and the input will read high. As soon as you open the door that will be shorted to ground, you'll have a 0.5mA current flowing through the resistor to ground and the input will read low.
Now go back to the scenario of using that door switch circuit to power some extra lights. Right, so doors open, one side of the relay at 12V from the battery, other to 0V from the door, current flows, relay energises, lights on. Good. So we close the door, now there is a path from 12V through the relay to the input of the 10AS. Now there's nothing pulling the -ve side of the relay to ground, the -ve side will rise to the same voltage as the +ve side, that is 12V. Best case scenario is that it's built to cope but I don't know that. If it was me, I would hope that it would be fine but assume that it wouldn't be.
There is another issue with relays which is the voltage spike from the relay's magnetic field collapsing. That's really nasty for electronics that aren't expecting it. If you do go ahead with putting a relay in then please either use a relay with a diode, or fit a diode backwards across the control terminals. That will short circuit the relay in reverse so dissipate the energy stored in the field. In normal operation the diode won't conduct, but when you turn it off it can't spike if there's a suitable diode there.
To go back a step, what power are your additional bulbs and what are they doing? It will be much easier and probably less risky to just use the 10AS's output...
Post #501842 7th Feb 2016 9:04pm
PaulMc
The driver's door switch is on its own wire (Grey/White trace), which goes back to C0061-5 in the 10AS unit's Grey connector.
The wires (Purple/Blue trace) from all of the other door's switches, are spliced together and go back to C0061-16 in the 10AS unit's Grey connector.
To add extra interior lamps, you don't need to wire anything to the door switches.
The door switches signal the 10AS unit to provide an earth path to the interior lamps on the Purple/White trace wire at each of the interior lamps.
So, to wire additional interior lamps to fade on and off with the factory fitted interior lamps, you should wire them to the interior lamps permanent live (Purple/Brown trace), and the interior lamps 10AS controlled earth on the Purple/White trace wire.
. Paul.
Post #501844 7th Feb 2016 9:08pm
mcma1
You guys know your wire!!
Basically I have 4 of these, one going into each door card, don't want them to fade, just come on if a door is opened...
So what do I do?!!! :blub:
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Andy
2014 Corris 110 SW
LS3 V8 build...
Post #501851 7th Feb 2016 9:20pm
mcma1
So in my diagram do i just then use the 10AS Purple/White trace wire for my trigger? Andy
2014 Corris 110 SW
LS3 V8 build...
Post #501855 7th Feb 2016 9:28pm
mcma1
Don't leave me hanging guys or I will have to just use 4 9v batteries! Andy
2014 Corris 110 SW
LS3 V8 build...
Post #502496 9th Feb 2016 7:53am
Cupboard
What power is the bulb in the new thingy?
Post #502508 9th Feb 2016 9:04am
mcma1
Thought they would arrive today in the post but no show, I am pretty sure they will be the little 3w bulbs.. Andy
2014 Corris 110 SW
LS3 V8 build...
Post #502619 9th Feb 2016 2:01pm
Martin
Site Admin
Use the Purple/White from the 10AS. It is a switched earth as Paul has said.
You will have to provide your own permanent 12V in the door.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #502636 9th Feb 2016 2:48pm
mcma1
So no relay?? or this?
2014 Corris 110 SW
LS3 V8 build...
Post #502640 9th Feb 2016 2:59pm
Martin
Site Admin
You can add a relay if you want but they then won't dim.
I cannot see an extra 12W (~1A) being a problem.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #502643 9th Feb 2016 3:05pm
mcma1
Dont want them to dim but dont want to expose the 10AS to any risk? Andy
2014 Corris 110 SW
LS3 V8 build...
Post #502647 9th Feb 2016 3:09pm
Page 2 of 4 <1234>
