Home > Puma (Tdci) > Engine Oil for Warmer Climates
Bushpig
Wales 2012 Defender 110 Puma 2.2 SW Alpine White
I'm about to do 80 000km service, but 5w-30 oil is not readily available here in Maun.
A supplier has suggested that I rather use 10w-40, due to the high ambient temperatures we experience here.
Winter averages 8 to 28 and summer 20 to 40+ (Celsius).
They can readily supply Castrol Magnatec 10w-40 (A3/B4) and at a much cheaper price compared to the 5w-30.
Is there any reason why I should NOT use 10w-40 in the 2.2 Puma?
Thanks in advance Human beings, who are almost unique in having the ability to learn from the experience of others, are also remarkable for their apparent disinclination to do so.
Douglas Adams
2012 2.2 Puma
Post #501532 7th Feb 2016 8:04am
dgardel
Italy
IMHO this is the best!!!
http://www.mobil.co.uk/UK-English-LCW/care...-5w50.aspx
 Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #501574 7th Feb 2016 11:34am
Bushpig
Thanks
Will contact supplier & see if this is even available.
But already doubting, as Mobil pulled out of South(ern) Africa many years ago... Human beings, who are almost unique in having the ability to learn from the experience of others, are also remarkable for their apparent disinclination to do so.
Douglas Adams
2012 2.2 Puma
Post #501637 7th Feb 2016 1:20pm
Sadi
Namibia 2016 Defender 110 Puma 2.2 Heritage Edition SW Grasmere Green
5W-40
Similar situation in Namibia - 5W-40 only available - probably due to higher ambient temperature most of the year.
Sent an email to Castrol ZA 10 days ago - there website is outdated and does not provide oil specs for the 2.2 Puma. Did receive an answer but not the required Castrol oil spec.
Still intend to drop by at the local dealer to enquire which engine oil they use.
Meanwhile this provides interesting reading:
http://lubematch.shell.co.za/na/en_GB/equi..._EFt8PjQtl
http://www.lubadmin.com/upload/produit/FichePDF/lang_1/162.pdf
http://www.engen.co.za/home/apps/content/p.../oats.aspx
My other vehicle is a 2011 BMW F25 X3 - BMW changed from Castrol to Shell as a preferred provider in 2014/-15.
In the 2.2 Puma I now carry 500ml Shell Helix Ultra 5W-40 - as 5W-30 is not available locally.
Hope this helps.
Post #501793 7th Feb 2016 7:38pm
Bushpig
Hi Sadi
Please let me know what the dealer says and would you mind asking them about using 10w-40?
I'm up near Shakawe and not getting response from Bots nor SA dealers.
Thanks Human beings, who are almost unique in having the ability to learn from the experience of others, are also remarkable for their apparent disinclination to do so.
Douglas Adams
2012 2.2 Puma
Post #501975 8th Feb 2016 7:03am
Sadi
10W-40..
Hi BP,
Just visited the local JLR dealership (with their last 2 ever Defenders on the floor..) - service advisor recommended either 10W-40 ( which was their previous "go-to" oil ) or 15W-40: which is what they currently use.
He did emphasize though that it should be a Fully Synthetic oil.
Regards !!!
Post #501998 8th Feb 2016 9:19am
Bushpig
Perfect timing Thumbs Up
A friend is coming up from Maun today.
I'll be using Castrol Magnatec, which is what LR has used on my previous services.
Thanks again for your help Bow down Human beings, who are almost unique in having the ability to learn from the experience of others, are also remarkable for their apparent disinclination to do so.
Douglas Adams
2012 2.2 Puma
Post #502019 8th Feb 2016 10:11am
HardCharger
I'm currently in a tropical country and am able to get my paws on LiquiMoly SpecialTec F 5W-30 (Ford Spec) which is perfect for my 2.4 Puma.
As for using other grades, the previous owner of my truck used (I was told) Shell Helix 15W-40 or 15W-30 which, again I was told, was what killed my turbo. So reading the posts above, I'm guessing that this may not be the case? While the local Shell has the special Rimula formula that can be used with the Puma, it's a special order oil and not the ones you find at the local fuel stations.
I'll watch this thread with interest as I won't probably have to spend a bundle on oil if I don't have to...
Post #502480 9th Feb 2016 4:09am
Naks
the problem with using oils other than what LR specifies is when something goes wrong, they will reject any warranty claims using this reason.
so be careful.
Bushpig, I use Fuchs oil conforming to the Ford specs, I'm sure you can get it delivered from CPT? --
Post #502484 9th Feb 2016 6:38am
