Home > Puma (Tdci) > Service Question
mse
Service Question
On the official service sheet (like the one i posted some time ago and is in my gallery) are the mileage specific tasks (gearbox oil at 120k as an example), equivalent to miles or the actual mileage?
Example:
Renew Transfer box oil is 48k service - my reading is that would be done at the 4th year which is equivalent to the 48K service?
Which would mean the gearbox oil gets changed at 10years or 120k...which ever is first!! Mike
Post #50068 28th Dec 2010 11:42pm
Grockle
which ever comes first, ie either time or mileage Mike,my dealer at the 2yr/24k service tried to charge me extra for greasing the prop shafts and the brake fluid change all listed on the schedule. txxxers ! 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #50092 29th Dec 2010 9:40am
dgardel
Italy
From LR service sheet
GLOSSARY:
MAIN SERVICE = The main service is applicable to all vehicles. It is carried out at 12 month or 12,000 mile intervals, whichever occurs first.
Main Service "A" is applicable at 12 months/12,000 miles, 36 months/36,000 miles, 60 months/60,000 miles 84 months/84,000 miles and so on.
Main Service "B" is applicable at 24 months/24,000 miles, 48 months/48,000 miles, 72 months/72,000 miles, 96 months/96,000 miles and so on. Some items do not need to be carried out at every main service and
these items are identified by an indicator in the tick box e.g. 60k (This indicates that this item is only applicable every 60,000 miles)
The gearbox is "filled for life" (means change the oil at 82,000 miles)
NOTE: The service required should be at the time or distance stated, which ever occurs first. Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #50093 29th Dec 2010 9:54am
mse
Thanks grockel
I know the normal A and B services are 12 months or 12000miles etc - like i said i posted the service sheet on here years ago Thumbs Up but it wasnt really my question
It was the odd items that have a SPECIFIC mileage so not the standard service intervals that dgardel mentioned (which is self explanitory!)
Just as an aside dgardel, the gear box according to the UK service sheet is 120,000 miles not the 82, 000 stated have a look in my gallery for my original posting Thumbs Up Mike
Post #50097 29th Dec 2010 11:00am
noworries4x4
Blimey does a Puma gearbox last 120thou ??
Ive had 2 already both went west at about 50thou yet still on same clutch at 150thou
And rear diffs on the 3rd one of them
Defenders realy arnt designed to be constantly bashing up and down the motorway network day in day out If everything is under control you are not going fast enough.
Every Day MY 20 Discovery 5 Commercial Workshop and Escort Vehicle
Weekends MY 12 L322 4.4 TDV8 Vogue
No Worries 4X4
Post #50101 29th Dec 2010 11:27am
mse
I hope they are because mine mainly does that!
I know the service lengths are worrying!! Mike
Post #50102 29th Dec 2010 11:28am
dgardel
Italy
82.000 is MY suggestion!!! Whistle Whistle Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #50103 29th Dec 2010 11:30am
mse
If we are on suggestions i wouldnt get much past 48k Exclamation Thumbs Up
Still not looked into fluid change on the box at all yet - i may suddenly think 300k is easier Rolling with laughter Whistle Mike
Post #50104 29th Dec 2010 11:35am
Toplink
The service intervals are a joke Rolling with laughter Rolling with laughter
I changed all my oils (except the G/box) at 1000miles.Axle oils were very dirty and the T/box was 1litre short of full! Engine oil and filter no problem. I fitted the axles with magnetic drain plugs. Since then I have done this every 6000miles,fuel and air filter every 12000miles.Propshafts are greased every 1-2000miles.
I have not touched the G/box as I want to see how long it lasts.
My grandfather was a motor engineer in the early 1900's.He always said to me that the cheapest things you can buy for a motor vehicle is oil and grease.
I took up the issue of the dirty axle oils with 2 local Stealers.To which I was told this is perfectly normal,which is why I do all my own servicing and repairs.
I have a theory on the axle oils being dirty.I think that the quality of the machine finish is not as it used to be and they are relying on it lapping in through use.This would be fine if oils were changed at short intervals.
The more I see of future motor manufacturing the more I want to regress. Its never over in my land rover.
2007 Defender HTop.
1952 Series One 80"
1977 Muir-Hill 111.
2014 Triumph Tiger800xc
1999 Discovery 2 td5
1982 Ransomes TSR300D.
2002 Yamaha XT600e.
2010 Freelander2 (the wifes)
2008 John Deere X140
Post #50776 2nd Jan 2011 10:23pm
dgardel
Italy
what do yo mean with "dirty"?
the foggy-black color is given by the MoS grease on the CV-join..... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #50784 2nd Jan 2011 10:52pm
mse
I think there is a balance.
Materials have improved as have the oils and the chemicals used...there have been many advances and this does allow a longer service - i do believe that.
Whether some of the intervals are proven or appropriate...who knows...certainly there are terrian factors.
Motorway vs African Bush have their different demands.
That said - i knew a taxi driver that would buy cheap oil and change it and the filter every few thousand miles.
My view is get the best quality oil and change it at the manufacture's interval or less on balance of other factors. Mike
Post #50787 2nd Jan 2011 10:56pm
dgardel
Italy
I agree 100%!!!!!!! Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #50788 2nd Jan 2011 11:07pm
Toplink
[quote="dgardel"]what do yo mean with "dirty"?
the foggy-black color is given by the MoS grease on the CV-join.....[/quote]
No dirty metalic oil in front and rear axle.The cv grease is stealer speak. My 200 tdi Disco never had the grease colouring the axle oil in 200k miles.(and yes it had grease and not oil).
As my 90 is a working vehicle on and off road I will stick to my 6000mile services.Quality oil is realy cheap compared with metal parts. Its never over in my land rover.
2007 Defender HTop.
1952 Series One 80"
1977 Muir-Hill 111.
2002 Yamaha XT600e.
Post #50795 2nd Jan 2011 11:46pm
MK
having oil on wheel bearings or MoS2 in the diff is another plus from LR Twisted Evil Puma 110" SW
Post #50800 3rd Jan 2011 12:29am
mse
I dont think anyone is disagreeing Thumbs Up
I think there is an expression of balance...actually you want longer service intervals (and this can be positive for the components as well) for a cost, environmental and serviceability perspective.
I think there has to be an acknoledgement that the componets have changed and arent 100% the same as the 200 or 300tdi (or even TD5).
Im not sure what you mean by the cv grease is stealer speaker. On the 200 and early 300's there was a filler for the cv's when they were oil and then through the transition to grease for life...moving now from the late 300's you can no longer drain them Mike
Post #50809 3rd Jan 2011 1:27am
