Home > Wheels & Tyres > Spare Wheel Cover on 265s
stephan123
Hi all,
Looking to upgrade all 5 tyres from the 235s to 265 BFGs but wanted know if my standard vinyl Land Rover spare wheel cover is designed to fit over the wider tyre. Any help would be much appreciated!
Stephan
Post #500597 4th Feb 2016 9:27pm
L90Andy
United Kingdom 1997 Defender 90 300 Tdi ST Nato Green
Yep, mine fits over the Goodyear 265 no problem. Only care point is not all 265's are the same size! But you should be OK.
Post #500663 4th Feb 2016 11:23pm
stephan123
Cheers L90Andy
The tyres I'm after after are 265/75 16. Thanks again for your help!
Post #500792 5th Feb 2016 11:55am
Martin
Site Admin
How much "overhang" does your existing wheel cover have over the back of the 235/85 tyre?
265 tyres are wider but no bigger diameter  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #500793 5th Feb 2016 11:56am
L90Andy
stephan123 wrote:
Cheers L90Andy
Yes I know, I meant that not all manufacturers make their 265/75R16's the same size so there are slight differences between brands. Either way, I think there is enough slack in the cover to fit the worst case size.
Here is mine with the cover over a Goodyear 265/75R16: http://www.defender2.net/forum/topic39625-15.html
Only thing I had to do was wind out the spacers on the mounting studs to provide clearance for the rear window wiper.
Post #500796 5th Feb 2016 12:07pm
Litch
As already stated, not all 265/75x16 (or other sizes for that matter) are the same size so what might fit one tyre may not fit another.
When I replaced my 265/75x16 BFG AT's for 265/75x16 ST Maxx I found that the new tyres were 1-inch taller and 1-inch wider than the old ones and the old semi-rigid cover didn't fit. Funnily enough, I had the same problem when I first fitted the BFG AT's, the cover that fitted my old (same size) tyres wouldn't fit the BFG's!
For the ST Maxx (31.5 in tall & 10.5 in wide) I eventually went for a soft cover off Ebay, cheap & cheerful but it does the job. I really wanted another semi-rigid but when I spoke to the manufacturers, both said that they didn't have anything that would fit the larger tyres. ONE LIFE, GET IT!
Post #500844 5th Feb 2016 2:07pm
stephan123
Here is a pic showing the current overhang on the standard 235 contis. Reckon it will be too tight with the additional width. Will most likely leave spare unchanged and just upgrade the 4 main tyres. Thanks again for all the feedback!
P.S. hope the photo comes through, first time I have posted a pic Shocked
Post #501243 6th Feb 2016 1:22pm
