Home > Technical > Battery cables
ibexman
Battery cables
What size battery cables from battery to 6/12 way fuse board
Post #500457 4th Feb 2016 3:19pm
PaulMc
I use 16mm˛ flexible battery cable (203/0.30mm), rated at 110A, from the battery + terminal, via a 100A Midi fuse -
. Paul.
Post #500460 4th Feb 2016 3:27pm
miker
That really depends what load you plan to put on the first board!
Post #500464 4th Feb 2016 3:41pm
mikeh501
if its the bluesea board a few people are using then its rated at 110a i believe.
Post #500491 4th Feb 2016 4:52pm
