Home > Puma (Tdci) > front diff oil seal
giacomo.m
Italy
front diff oil seal
Hi all,
I have to replace a front diff oil seal on Puma 2.4 tdci 2009,someone knows the right pinion bolt torque value ?
thank you
Giacomo
Post #500265 4th Feb 2016 11:30am
see below...
M12 x 30mm if Parts manual is correct!
Post #500448 4th Feb 2016 3:54pm
From the Puma WSM:-
Installation
1 . Clean pinion oil seal recess and pinion flange.
2 . Lubricate oil seal lip with clean oil.
3 . Using LRT-51-010 fit pinion oil seal.
4 . Fit pinion flange.
5 . Restrain flange using LRT-51-003 and fit bolt. Tighten bolt to 100 Nm (74 lbf.ft).
6 . Position drive shaft to differential housing and align reference marks.
7 . Fit flange bolts and tighten to 48 Nm (35 lbf.ft).
8 . Remove stands and lower vehicle.
9 . Top-up differential oil level.
This is curious since the "Torque Specifications" table at the beginning fo the WSM section says:-
Bevel pinion nut 130 Nm
... even though (a) this conlficts with the section quoted above, and (b) the bevel pinion on all Pumas is retained by a bolt not a nut.
The Puma WSM is riddled with errors, contradictions, and anomalies like this though.
I've always gone with the 100Nm figure.
Post #500456 4th Feb 2016 4:18pm
Isn't there a flange tool required for this or at least fashion something of your own?
Maybe the OP has this but I swear it is needed to tighten it up.
Tis' worth checking the flange isn't worn too wwhile at it or it may still leak even with a new seal.
Post #500499 4th Feb 2016 6:18pm
Yes, LRT-51-003, but it's very easy to make one or to improvise.
Post #500525 4th Feb 2016 7:27pm
Thumbs Up
Post #500527 4th Feb 2016 7:34pm
giacomo.m
Italy
Thank you blackwolf Thumbs Up
Giacomo
Post #500607 4th Feb 2016 9:39pm
John110
Ireland 2007 Defender 110 Puma 2.4 HT Stornoway Grey
I just failed our equivelant of your mot today with this leak. Thanks for the guidance- I'll be tackling it over the weekend Thumbs Up
John For those who understand, no explanation is needed...
For those who do not understand, no explanation is possible
Post #500674 4th Feb 2016 11:45pm
Failed for a leak ? Was it particularly bad.
I had an advisory for the rear when I had it but it was a weeping leak and UK MOT.
Is yours different / more stringent then?
Post #500686 5th Feb 2016 12:39am
John110
Not too bad, axle was wet but not leaving a mark on the ground after parking. I thought he was a bit harsh. I'd imagine it's tougher over there with vosa stopping hgvs and checking them day and night
Post #501002 5th Feb 2016 8:53pm
MikeJ
United Kingdom 2013 Defender 130 Puma 2.2 HCPU Fuji White
Thanks for this write up - changed the front seal on my 130 cherry picker today.
I simply put it back on the wheels to tighten up the pinion bolt - no special tool required!
Sadly, the leak has turned out to be a cracked weld on the axle.
Crying or Very sad
Mike
Post #640723 30th Jul 2017 5:07pm
Mike, is the crack in the weld holding the end flange to the axle tube and is it 2012 vehicle? If so, read this thread. There was a recall for this on 110 and 130 models, but not 90s.
Post #640787 30th Jul 2017 9:42pm
MikeJ
Thanks for the heads up on this.
It's a 2012 2.2, and I think the recall doesn't include my vin number.
The crack is in the seam along the front of the axle close to the nearside end.
It's a 3.5 tonne cherry picker and has HD suspension, so I'll speak to a dealer.
In the meantime, I stuck some chemical metal over the crack to try and keep the oil in.
Mike
Post #640833 31st Jul 2017 7:33am
