Home > Puma (Tdci) > Drive Flanges
Page 1 of 3 123>
Scotm
Scotland 2012 Defender 110 Puma 2.2 SW Orkney Grey
Drive Flanges
On my factory tour I noticed the rear drive flanges on the defenders coming of the production line were different from my 2012 model. They didn't have the plastic caps. Is this an upgrade and if so would it be retrofitable to mine when the time comes?
Post #498040 29th Jan 2016 9:36pm
thor44
2014 Defender 90 Puma 2.2 SW Indus Silver
There's a HD version available. They come with a screw-on cap. Could that possibly be what you've seen?
(Picture taken from paddock)
Post #499487 2nd Feb 2016 12:05pm
shaggydog
They are the older design of half shaft as used on early 90's and Discoverys Thumbs Up
Imagine someone has welded your half shaft to the drive flange and made it look a bit prettier - that's basicly what they are.
Some argue they are better as it removes one pair of drive flanges from your axles - less splines to wear out, others argue by removing the drive flange you are more likely to damage the half shaft or diff - removes an easy to change week point. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #499491 2nd Feb 2016 12:20pm
Scotm
It was the ones coming off the production line with the thin one shown in the picture. Could they have changed back to earlier design? Would this be due to the 150hp tune on limited edition models?
Post #499495 2nd Feb 2016 12:48pm
shaggydog
You could do I suppose, you would need to check the number of splines as it can be a bit of a nightmare but I'm sure if you went to your local dealer you buy a brand new one off the shelf and it fit fine Thumbs Up
I doubt its to do with the tune, they probably found a crate to use up - so they did! Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #499498 2nd Feb 2016 12:53pm
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
Sorry to ask and hijack this thread but - during a recent service the indy said one side of my rear drive shafts and flange was getting worn, possibly because it was running dry on that side. Is that something that can be replaced easily, would you do both sides, and use o/e parts or are pattern parts ok?
Post #499502 2nd Feb 2016 1:26pm
ROBBONTHEROCK
Scotland 2007 Defender 110 Puma 2.4 XS CSW Firenze Red
If its the separate type, i.e. separate flange type, the genuine LR ones are about £10 or less each, cheap enough to not consider pattern parts (I think).
Island 4x4 supplied mine Wink
Post #499507 2nd Feb 2016 1:48pm
Devon-Rover
I noticed this and asked during the factory tour, but our guide wasn't able to tell me ( He hadn't noticed to be honest). Microcat isn't showing any change of rear driveshaft arrangement on the system either. I would hazard a guess and say that Land Rover have acknowledged the rear drive shaft - flange wear, but not made an 'Official announcement'. Just quietly backward superceded the parts. I will ask my friends on the inside at the local dealers if they have any knowledge.
Post #499644 2nd Feb 2016 8:20pm
jst
i reckon they had some old ones kicking about that needed using up. i would rather run the two piece affair. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #499676 2nd Feb 2016 9:25pm
shaggydog
The 2 part system is better for me too Thumbs Up Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #499707 2nd Feb 2016 10:30pm
Toplink
I changed mine for the one piece ones a while back. Far better than 2 piece ones I chewed through 2 sets of flanges in 90k Its never over in my land rover.
2007 Defender HTop.
1952 Series One 80"
1977 Muir-Hill 111.
2014 Triumph Tiger800xc
1999 Discovery 2 td5
1982 Ransomes TSR300D.
2002 Yamaha XT600e.
2010 Freelander2 (the wifes)
2008 John Deere X140
Post #500098 3rd Feb 2016 10:18pm
Happyoldgit
That sounds more likely. I doubt very much if they would have acknowledged any problems exist right at the end of production, especially given the history of not admitting their have been problems with the intermediate shaft since 2007 ...or indeed water ingress over the past 68 years. Steve.
Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades.
Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone.
http://forums.lr4x4.com
Post #500257 4th Feb 2016 11:17am
Caterham
yep - I'd go with that.
water leaks - are you sure. I'd always assumed the issue was condensation resulting from my sweaty feet?
Post #500264 4th Feb 2016 11:29am
Martin
Site Admin
Might be a cosmetic thing since the Heritages were fitted with steel HD wheels where the centres are visible.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #500266 4th Feb 2016 11:31am
Avion8
Australia 2015 Defender 90 Puma 2.2 Heritage Edition SW Grasmere Green
I just checked my Heritage & it seems to have the 2 piece set up with seperate drive flanges. Also has a plastic hub cab:
I was thinking of getting the HD versions when these wear out, but they would look totally out of place.
Post #505702 18th Feb 2016 3:45am
Page 1 of 3 123>
