Home > Technical > steering rod UJ but not Britpart?
Chamois
2002 Defender 110 Td5 CSW Zambezi Silver
Any idea where to go for a steering rod replacement UJ trying not to buy Britpart? Winter's here, thanks goodness!
Post #499979 3rd Feb 2016 5:34pm
Martin
Site Admin
If you mean steering column, Bearmach do pattern ones
Lower: http://www.advancedfactors.co.uk/nrc7704-b...8573-p.asp
Upper: http://www.advancedfactors.co.uk/nrc7387-b...8654-p.asp  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #499981 3rd Feb 2016 5:43pm
mk1collector
Landrover? Ray
My build thread
Post #500007 3rd Feb 2016 6:55pm
Martin
Site Admin
True Laughing  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #500009 3rd Feb 2016 6:58pm
mk1collector
Post #500015 3rd Feb 2016 7:04pm
Chamois
mk1collector wrote:
Landrover?
Hadn't crossed my mind? Winter's here, thanks goodness!
Post #500021 3rd Feb 2016 7:07pm
Chamois
I dunno what you call it, the steering column is what goes through the bulkhead then there's this rod with a UJ at each end.
Upper steering column UJ?
Don't think you can buy the UJ separate, comes with the steering column lower rod assembly? Winter's here, thanks goodness!
Post #500031 3rd Feb 2016 7:31pm
You mean the ujs on the column between the bulkhead and the steering box?
Expensive from LR the last time I looked.
Post #500033 3rd Feb 2016 7:36pm
Chamois
Yeah that's it, Brit part do the assembly for £60. Rimmerbros LR is £300+
Slight variation on the price. Winter's here, thanks goodness!
Post #500036 3rd Feb 2016 7:45pm
Martin
Site Admin
Fill in your vehicle profile and we'll know what year and stuff applies.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #500085 3rd Feb 2016 10:01pm
Seems a few come looking for help but don't complete this section - can you make it mandatory, obviously with an option of nil for those that don't have one?
Post #500235 4th Feb 2016 10:40am
Happyoldgit
Senior moment. Deleted. Steve.
http://forums.lr4x4.com
Post #500241 4th Feb 2016 10:59am
Martin
Site Admin
That's effectively what's then now, there has to be an option for "None", and if it defaulted to a model then we would get a bunch of registrations with that set and nothing else Wink  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #500244 4th Feb 2016 11:00am
I think the part you need is QME500031
Pre-TD5 the UJs were replaceable independently, but TD5 on the shaft must be changed. The 2.4 TDCi shaft will fit a TD5 but (at least in theory) but the TD5 shouldn't be fitted to a TDCi since the Puma shaft has an additional heat shield to protect one of the joints from the heat of the cat. I don't know if the 2.4 and 2.2 shafts are the same - I suspect that there's even more heat from the DPF/cat on the 2.2.
From what I remember when I needed one, the TD5 part is expensive if genuine and the TDCi part with the extra heatshield is eye-wateringly expensive (I think the heatshield must be made from Unobtanium, that rarest of all metals, to justify the price). In the end I bought a use part from a breaker, which was genuine and off a low-mileage write-off, but cost only about £25.
At any time you'll find a number on Ebay, eg this
I have bought stuff off this guy in the past and always been entirely happy with the accuraccy of the description and the speed and quality of service.
Whilst the price of the pattern parts is attractive, ask yourself if you want the steering wheel connected to the steering box by a safety critical component made by Britpart!
Post #500276 4th Feb 2016 11:36am
Martin
Site Admin
Agree on the part number for a 2002 Td5 Thumbs Up
There are options for this from £200+VAT for a genuine LR part down through £85+VAT for OEM via Bearmach or Britpart to £37+VAT for a pattern Britpart, Allmakes or Bearmach supplied part.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #500280 4th Feb 2016 11:48am
