![]() | Home > Puma (Tdci) > diesel filter location, filling port for transfer case/gearb |
on a rt hand drive vehicle you access it from the rear offside wheel looking forward. there is a small turning clip which needs to be released then it ll come out. it looks like an oil filter. have a look and if still cant see it i ll do a pic for you tomorrow
simonwg905 Member Since: 28 Dec 2010 Location: HK Posts: 2 ![]() ![]() |
THX Big Mike!!!
Mine ia a Rt hand drive puma............do u mean rear left wheel arch.........as "Off-side"? Is it underneath the chassis or right under the 2nd row passenger seat or within the rear wheel arch? THX!!! BTW.......where is the filling port for the transfer case? |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2507 ![]() ![]() ![]() |
I know it is fun, but why do you want to change the gearbox oil? and just curious, what type of oil? Puma 110" SW
mse Member Since: 06 Apr 2008 Location: UK Posts: 5117 ![]() ![]() ![]() |
The fuel filter is on the same side as the filler.
Look for the odd shape box to the right on the wheel on the chassis - its behind that As for servicing, this is the time sheet: http://www.defender2.co.uk/gallery/albums/...0miles.pdf Mike |
Alexke Member Since: 03 Jan 2011 Location: Antwerp Posts: 113 ![]() ![]() |
i thought there was an service/acces panel for the transfercase under the cubby box !
Well given you can remove the floor and that particular seatbox section equally the same...yes...but its not really something you do at a service no. Mike |
