![]() | Home > Technical > Trailer warning light |
| Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6727
The lamp is illuminated by the flasher relay when it detects a trailer lamp load. It's not calculated by the lamp cluster.
1988 90 Td5 NAS soft top
2015 D90 XS SW |
| itolond Member Since: 16 Jan 2016 Location: Singapore Posts: 193
this is also typical for LED lights bulbs.
so its based on load for of a relay, wouldn't this be from standard tails lights?? the flasher would only have load on indicator use (is my assumption based ?) |
It uses the load from the indicators, not the tail lights.
I don't have experience of LED flasher units to be able to tell you what happens with LEDs, sorry. Martin 1988 90 Td5 NAS soft top
2015 D90 XS SW |
