Home > Technical > Can anyone identify this wire's purpose?
stooby do
Hi all, looking to install some rear speakers in my Td5 110 CSW, Removed the metal cover over the RHS rear light cluster and have found some serious bodging going on. Firstly, Red/Orange wire to RHS rear tail light has been cut and a new wire attached that goes around the rear door frame. I think this is for the rear sidelight. When I fitted a trailer socket last rear the RHS sidelight was not working so presume there is a break in the loom between trailer socket connector and fusebox. Looks like previous owner has taken a feed from the LHS rear side light to power the RHS rear side light but will check this later when I remove LHS rear light cluster cover:
What I am more concerned about was a bundle of insulation tape on the wires that come through the grommet in the cover plate. When I removed the tape I found a Purple/Blue wire that has been cut. This comes through the grommet in the cover plate with two more wires, one pink and one orange. Does anybody have a clue what this wire is for as I can't see any reference to it in the wiring diagrams in the Haynes manual I have:
Would be grateful if anybody can shed any light on this.
Cheers,
Stooby.
Post #499524 2nd Feb 2016 1:18pm
Romadog
Purple and blue will be to switch for interior light on rear door.
Pink will be to central locking actuator on rear door ?
Best do a google search for wiring diagram, better than haynes.
Post #499537 2nd Feb 2016 1:47pm
Martin
Site Admin
"Shed any light" - like it! Rolling with laughter
I agree the side light wiring is a bodge to get the RH sidelight to work.
The purple/blue is used for the tailgate switch, for the interior light. Is it connected/functioning?
The orange and pink I am struggling with, where do they go?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #499539 2nd Feb 2016 1:54pm
Martin
Site Admin
Nuts, beaten to it whilst my head was digging in the diagrams.
And yes, pink and orange are central locking Bow down  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #499540 2nd Feb 2016 1:55pm
stooby do
Thanks for the help guys. Have looked and the tailgate switch is missing completely! Just a hole in the door frame where it should be. My interior lights come on when opening the central locking with the remote and go off after 5 seconds or so, they don't come on when any doors are opened. Another job for the to-do list.
Thanks again for your help.
Post #499543 2nd Feb 2016 2:06pm
Romadog
Th interior light switch wiring normally comes from roof down beside door hinge area behind headlining and trim, stuck agaist metal with tape.
Post #499545 2nd Feb 2016 2:10pm
Martin
Site Admin
The end door switch is PRC8548
Sounds like all the door switches have been disconnected or disabled though Sad  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #499554 2nd Feb 2016 2:20pm
stooby do
just ordered pack of 5 OEM switches just in case any of the others are knackered or missing. I know one of the switches definitely works though as whilst working on a sticking actuator on the RHS middle door the other day, I central locked the car with the remote whilst inside the vehicle so I could watch the actuator, opened the door from inside and the alarm went off. Will figure it out hopefully.
Post #499560 2nd Feb 2016 2:26pm
Martin
Site Admin
You might have 4 spares Confused The side door switches are different - AFU4241L  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #499561 2nd Feb 2016 2:27pm
stooby do
ffs - lol!
Post #499563 2nd Feb 2016 2:32pm
Martin
Site Admin
Well, they might fit Smile Good luck Thumbs Up  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #499566 2nd Feb 2016 2:40pm
