Home > Technical > Recovery points
Page 2 of 3 <123>
Glynparry25
I have 2x Dixon Bate 3.5 Ton jaws on the front:
NATO hitch on the rear:
What more could you want?
Glyn :sheep:
Post #49938 28th Dec 2010 12:02am
BigMike
Glynn, do you not give the hitch a whack on steep descents? rock etc?
Post #49940 28th Dec 2010 12:12am
Glynparry25
I haven't had an impact on the rear hitch yet.... but I am sure I will at some point. It is well made (strange for a LR genuine part) and I am sure it will take any bumps even though I am thinking of making a skid plate for it.
Glyn Sheep
Post #49942 28th Dec 2010 12:21am
BigMike
Did you see the shackle and point I have on mine?
This one
I thought long and hard about the rear and reasoned that if circumstances get a bit extreme I'd rather break that or bend the rear crossmember than bend the chassis. I towed a 15 tonne plus gritter with it before christmad with no problems. but having said that, your rear step combination is still pretty cool Laughing
Post #49943 28th Dec 2010 12:24am
Glynparry25
Yeah, I must admit that if I didn't have the use for a hitch I would have gone for the same as you. Fully swiveling so good for all angle pulls. Looks smart too Thumbs Up
Glyn Sheep
Post #49944 28th Dec 2010 12:28am
BigMike
speaking of angle pulls I just watched the top gear desert special thing, and saw what happened to may during one of their more dubious recoveries. amazing really.
Post #49945 28th Dec 2010 12:31am
Zinke
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
At least they didnt edit it out and it shows how easily things can go wrong when you dont know what your doing!
Pete.
Post #49947 28th Dec 2010 1:19am
mse
This one
I had one of those, fitted above the lr nas step on the cross member...taken it off now, still wondered if i should put it back on...dixon bate on the rear though. Mike
Post #49957 28th Dec 2010 11:18am
leeds
Some photos of rear recovery points on our vehicles. No one system will be best for everyone has we all have different needs/uses for our vehicles.
Red 110 has two welded on recovery loops and a Southdown tank guard system
The Southdown Recovery eye is fitted by pulling two pins out and exchanging it for the plough/towball
The Southdown recovery eye looks like this. Nicked from their website
On black 110 we have a 2" receiver fitted and can interchange drop plate for a recovery billet
HTH
Brendan
Post #49991 28th Dec 2010 3:55pm
mse
Just note the drop plate is not legal for towing trailers etc in the Uk Thumbs Up Mike
Post #50005 28th Dec 2010 6:08pm
BigMike
brendan, on your last pic, assuming the vehicle is a puma, how did you get the back plate on? did you drop the tank?
Post #50006 28th Dec 2010 6:09pm
bob neville
Mike are you referring to the plate with the six bolt heads showing ?
If you are it picks up the existing six captive nuts in the crossmember.
Bob
Post #50008 28th Dec 2010 6:30pm
BigMike
The holes are threaded, Bob. Didn't know there were captive nuts on the back? No access to put the back plate on.
Post #50011 28th Dec 2010 6:34pm
bob neville
Mike
Maybe captive nuts was the wrong term Thumbs Up
The front plate bolts directly into the threaded part of the crossmember, there is no back plate to fit behind the crossmember. There are a couple more pick up points that are secured with nuts and bolts. Two side arms run along the chassis and are secured on the tie down eye bolts.
Very easy to fit, took me about 30 minutes to install mine.
Bob
Post #50012 28th Dec 2010 6:43pm
leeds
Interesting, can you point me in the right direction for more information?
Mike, yes it is an 09 Puma. IIRC on Pumas it has six captive nuts, whereas on 300 TDi you get a plate with 6 nuts welded on.
With the standard tank it is a straight forward fit. We have a 120 litre tank on so can not remember if we fitted it before or after the tank. It is too dark to crawl underneath now to see ease of fitment with the large tank on. If I remember will crawl under it in daylight and have a look
Brendan
Post #50013 28th Dec 2010 6:44pm
Page 2 of 3 <123>
