Home > 130 > Wheel spacers for defender 130
ben-yates
United Kingdom 2015 Defender 130 Puma 2.2 HCPU Santorini Black
Hello all, i have a 130 hcpu and im looking to put some spacers on as i want to run 285 tyres but dont want to make the turning circle even worse.
so my question is how are wheel spacers if you occasionally have weight in the back?
cheers
Post #499086 1st Feb 2016 2:12pm
AJC
Should be fine Ben
Post #499096 1st Feb 2016 2:35pm
ben-yates
Good news,
Cheers mate
Post #499098 1st Feb 2016 2:38pm
geobloke
HI Ben. Should be fine. Although I drive a Defender that is 20" shorter than yours, I have run wheel spacers for nearly a decade now and my truck is never empty and has a full roll cage to add to the weight. They make a super difference. What I will say is that with 30mm spacers and 285 tyres you are definitely going to need extended wheel arches. Also, when you fit them use threadlock on the spacer retaining nuts and torque them up properly, a case of learning through experience this... Whistle
Post #499186 1st Feb 2016 6:33pm
CarMan
Sorry to jump in here but hopefully relevant. I've seen Raptor 30mm spacers on a well know web auction sight at just under £100 posted - anyone know if they are respected brand? Rob
1993 200tdi 90 hard-top
1998 300tdi 90 soft-top
Post #499191 1st Feb 2016 6:39pm
AJC
Plenty of people run 285's with standard arches. Is it because his is a pickup?
Post #499231 1st Feb 2016 7:36pm
david110
Scotland 2015 Defender 130 Puma 2.2 HCPU Santorini Black
Yes, 130 HCPUs don't have rear spats fitted as standard. Going to fit rear ones to mine soon.
Post #499364 1st Feb 2016 11:01pm
AndrewS
Spacers will be fine you will probably have to fit arches to the rear.
The shape and radius of the tub arch is not the same as the 110 or 90. 130's have feeling's as well you know Smile
Post #499402 2nd Feb 2016 12:50am
