Home > Off Topic > 12v accessories (ciggarette socket)
Right just looking for some opinions here.... I have a 57 Def. 90 and also a Garmin 1300T satnav. Now the satnav ciggatete lighter plug get's annoying sticking out close to the gears but does work perfect. However have a Maplin 4 in 1 12v ciggarette adaptor of which is neater and doesn't get in the way. This i would like to use. The thing is I have used it but for some reason the fuse on the 4 in 1 adaptor has blown (10A 20mm glass quick blow) the fuse on the satnav is fine no problems there. Now thing is is there anything that could of caused it? I am not sure of the ampage of the satnav but surely that wouldn't have blown it? Any thoughts or should i just get some new fuses of the same type? But will they blow again Question I also cannot find the ampage of what the satnav uses Evil or Very Mad
Post #49901 27th Dec 2010 6:52pm
BigMike
i have a garmin nuvi and had the same issue re plug. i cut the plug off, took off the dash and wired it to the back of the lighter socket and ran the cable down behind so now there is no cable or plug to worry about.
Post #49905 27th Dec 2010 7:07pm
Lorryman100
I have a tomtom and bought and fitted the permanent wiring kit. Same as Mike, wired it to the cigarette lighter and fed the feed cable through the top of the dash. The thing to be careful off is the supply voltage to the satnav. The tomtom is 5v and has a built in voltage dropper in the cigarette lighter plug. The fitting kit for the tomtom also has this dropper. The Garmin GPS 276C unit I have is 12v and does not need a voltage dropper. Hope this helps Thumbs Up
Post #49907 27th Dec 2010 7:13pm
But cutting my satnav wire would void the 12 months warrenty. What I think i'll do is get some new fuses for the 4 in 1 adaptor. failing that a new adaptor. especailly seeing as fuses are about £2 and an adator £5 Laughing
Post #49930 27th Dec 2010 10:17pm
mse
If the sat nav has a seperate power cable - i fail to see how that would void the warranty - however, if it did just buy another Thumbs Up Mike
Post #49931 27th Dec 2010 10:56pm
If hard wiring sat nav etc in make sure the accessory is 12V I've seen many a gadget bricked as it was a 4v etc
Post #49934 27th Dec 2010 11:13pm
You obviously don't know my local Halfrauds then Laughing Whistle
Post #49965 28th Dec 2010 11:59am
mse
Well my point was just to buy another and cut the end off that - doesnt really do anything to your warranty and who's going to know.
Secondly - you could always return it without the power cable if its faulty - to be hones the oikes at halfrauds only just know what a car is let alone what should be in the box for an exchange and if they noticed, take the cable out of the replacement and give it back as you "left it at home" Mike
Post #49976 28th Dec 2010 12:38pm
I follow what you mean Thumbs Up It's just annoying how the Defender tdci socket is in that exact place as almost anything you put there interferes with the gears. Was the TD5 the same Question
Post #49982 28th Dec 2010 2:29pm
mse
Mine doesnt get in the way of the gears to be fair Mike
Post #49985 28th Dec 2010 2:46pm
with an angled 12v plug it's no problem it's the big plugs that stick out and cause it
Post #49994 28th Dec 2010 4:39pm
mse
our tomtom one is large but ok. Mike
Post #50002 28th Dec 2010 5:50pm
