![]() | Home > Technical > LED Lighting Upgrade on Puma Defender - Advice needed |
Led lights from the likes of bolt on bits are a plug and play fit (if you get the tdci specific kit) so no problems other than you need to fit the specific (supplied if you buy the full kit or can be bought seperately) new relay for the indicators. Ray
LED bulbs (units) fitted in standard lenses are illegal due to 'E' marking laws and regs.
CAN BUS not required on the Defender bar indicators but the best route for them is a Wipac or RDX relay which does the job for you inc trailers. For all Aux lights, brake, indicator etc there is two options. Wipac or RDX LED light kits which are legal due to bring tested and 'E' marked, combine this with again either brand's relay and you are good to go. I have RDX on mine, lights and relay. Very pleased with it indeed! Headlights wise a straight swap but I have non LED crystals myself with upgrade bulbs. You do have to bear in mind the heat issue with LED's in very very cold weather especially headlights. Due to them not producing heat as regular bulbs do snow or ice can build up on them reducing light, or worse next to nothing. If the weather gets as bad as that in this country though I wouldn't advise driving in such conditions anyway. But for this reason I went for LED on everything inc side repeaters but Crystal headlights and upgrade bulbs. Last edited by custom90 on 31st Jan 2016 8:58pm. Edited 1 time in total |
Morepower Member Since: 08 Jan 2013 Location: Fife, Scotland Posts: 630 ![]() ![]() |
Agree with Steve... I have LED Nolden's And Wipac Crystals... I use the Noldens most of the time, But swap to the Wipacs occasionally if it looks as if we're going to have a period of constant snow...
Regards Tim It doesn't matter how bad it is, It can always get worse... 2013 Bowler 110 (Sold) 2016 Bowler 90 Rally Spec (Sold) |
