Home > Wheels & Tyres > Rear door mount issues
peterl
1987 Defender 90 300 Tdi HT Epsom Green
I have a set of 16" bowler rims (which by the way are fantastic), but I have gone to mount the spare on the door and with the alloy nuts supplied, when they are screwed in, the wheel is loose, either I need a spacer behind the wheel or I need nuts with greater depth...
Has anyone else experienced this and which route did you go down to get it secure.
pete
Post #497509 28th Jan 2016 7:36pm
jomara
Scotland 2014 Defender 110 Puma 2.2 XS CSW Santorini Black
Hi Pete
When I had my 18in Bowler wheels fitted the adjuster nuts behind the wheel were wound out to suit the offset before it was fitted to the carrier, yours may need a bit of fettling, you can see them on the image below.
Hope this helps
John
 2014 110 2.2TDCi XS Station wagon - GONE
1971 Bowler Tomcat 88 4.2 V8 Auto
2022 110 D250 XS Edition - GONE
2024 110 D250 X-Dynamic HSE
Post #497514 28th Jan 2016 7:45pm
peterl
Thanks for that. The set up on mine is different, I will take a photo in the light and post it up.
pete
Post #497542 28th Jan 2016 8:51pm
