Home > Technical > PTO for TDCI
rodstir
2007 Defender 90 Puma 2.4 HT Cairns Blue
PTO for TDCI
Hi
Just after some info on the TDCI regarding fitting a PTO to the gearbox. Is it possible? What systems are out there? Anybody completed this mod?
Thanks
Rodstir
Post #46971 1st Dec 2010 7:00pm
The bloke that lives down the road from me, works for Scottish & southern elctricity, drives a nice shiney puma 110 with a whacking great PTO winch on the front (he used to have a Td5 110 with same winch), so yes, they're available.
transfer box on the puma is the LT230, same as all the previous models of 90/110/130, so fitment shouldn't be a problem at all; if you're retrofitting an older winch "kit" onto a puma, it'll just be (i think...) a case of getting the PTO shafts the right length (not sure how much further forward or back the geabox is mounted on a puma compared to say, a Td5)
Post #46990 1st Dec 2010 8:53pm
AndrewS
Could it he a Hydraulic winch he has Question driven off a PTO driven hydraulic pump Question 130's have feeling's as well you know Smile
Post #47000 1st Dec 2010 9:38pm
rodstir
Thanks for the info guys.
i am planning to run a Godiva fire pump in the back of truck.
Any ideas how the PTO is engaged is it electronic or manual?
Post #47008 1st Dec 2010 10:27pm
22900013A
SSE went over to electric winches now, not PTO driven, even the last TD5s they had had leccy winches. I have never seen a puma with a PTO winch. Neutral 2011 110 USW
1973 Series III 1-Ton
1969 IIA 1-Ton
1966 IIA 88"
Post #49735 25th Dec 2010 1:51pm
Lorryman100
Post #49739 25th Dec 2010 2:36pm
nakatanenga
Germany
Won't fit until you replace the x-member. The LT230 box moved 70mm backwards with the Tdci. So the PTO interfers with the x-member.
AFAIK no fit and forget PTO available for Tdcis
Peter WANTED:
SII or SIII in max 1.5k
Post #49744 25th Dec 2010 5:18pm
Lorryman100
once I get the dimensions for the pump I will go underneath and measure it up, The propshaft is my main concern so maybe a lift? Or one of X eng propshafts. The other idea was to cut out a section of x member and reinforce with a plate on the opposite side.
Post #49746 25th Dec 2010 5:26pm
nakatanenga
Germany
unfortunately the rear propshaft....
With a special made x-member it should work WANTED:
Post #49748 25th Dec 2010 5:32pm
I'll pop over later and ask him if i can take some piccies of it. to be honest i've never looked closely to see if it's hydraulic or electric or mechanical. it looks like a big mechanical husky, but i could be wrong.
Post #49812 26th Dec 2010 1:41pm
tacr2man
There are two take off points for pto on a LT230 transfer box, in the back and underneath , you can then either fit a prop type mech takeoff or a hyd pump . the undernaeth option is a lot more expensive than the rear , due extra castings etc,
Post #49970 28th Dec 2010 12:29pm
Yannis
United Kingdom 2015 Defender 90 Puma 2.2 CSW Corris Grey
Has anything become available for a hydraulic pump on the 2.2 in the 10 years this thread has been dormant?
Post #811113 20th Jan 2020 9:54am
hank
2.2, 2.4, TD5... Makes no difference. All Defenders use the LT230 Transfer box which is where the PTO hydraulic pump fits, just run and mount the hoses where you wish.
Quite a few options available from a quick google search. For example http://www.lr-winches.com/Parts/Power_Take...ender_PTO/ > 110 XS Double Cab
> Instagram @simonlanemind
Post #811119 20th Jan 2020 10:22am
Yannis
I believe from reading previous posts it’s not so simple on the 2.2/2.4. The transfer box moved back and now the Rear Cross member gets in the way of mounting anything.
Post #811120 20th Jan 2020 10:25am
hank
From what I understand the rear crossmember doesn't have the PTO drive hole, but if you just want a hydraulic pump and not a shaft to drive a PTO at the rear then it's relatively straightforward
2.2 specific kit https://www.ebay.co.uk/itm/Land-Rover-Defe...2602925846 > 110 XS Double Cab
Post #811121 20th Jan 2020 10:26am
