![]() | Home > Tdi > 300tdi PAS whine |
PAS pump is constantly engaged/driven, is there any play in the pulley/pump with the belt removed? 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
jonnytatt Member Since: 04 Jun 2015 Location: Oldham Posts: 37 ![]() ![]() ![]() |
No there is no play in the pully with the belt off.
i must just have a slighlty noisier PAS than some . Unless its normal and im just being anal. Ive not got another running 300tdi to compare too |
I might add its more notable when the temps of the engine are up. Perhaps this is because the steering fluids are warmer due to usage
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 ![]() ![]() |
I've recently changed my belt, water pump and alternator, my steering pump doesn't make a noise! My 109 thread
my youtube channel |
Bumpymike Member Since: 18 Nov 2015 Location: cheshire Posts: 71 ![]() ![]() ![]() |
Try bleeding the steering box ... If not sounds like pump drawing in air.
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8360 ![]() ![]() ![]() |
^^^ could be air, bleed it again.
some do whine. How old is the pump? miles? Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
Hello anyone ever had expericance with a steering box whining.
i thought it may off been the pump. Its not Ive had my long listening stick on it and its whiney when i rev the engine. Noise disapears with some turn of the wheel. Model is 300tdi so 4 bolt box |
Simple question , anyone ever encountered steering box whine with rpm of engine.
Ive never heard it before . Its defonatley not my pump. Thanks. |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6695 ![]() ![]() ![]() |
Hi, please don't ask the same question multiple times as you already have a thread with replies, I've merged everything together
![]() Check fluid level in the reservoir, and whether it looks frothy/bubbly. It shouldn't. ![]() ![]() |
As you still having problems I would grab an assistant and a round file, placing the file against a component and the handle against your ear amplifies the sound, get the assistant to hold a variety of rev ranges whilst you check all components, just because they are new it doesn't rule them out.
Bleeding of the pas system is jack up the front wheels (less stress on components) engine on idle and go lock to lock, if this doesn't work there is a bleed screw I top of the steering box. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 ![]() ![]() ![]() |
If you haven't done so, drain the old fluid, refill with new, run and cycle it a few times, then drain and refill.
I'm not sure if there is a specific flush for it but it might just be in need of an internal clean. The power steering pump is very often forgotten on services and the oil can go off a bit. Otherwise take a video and upload it? Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter ![]() |
Thanks for the help. Ive narrowed it down by using a bar to my ear .
Its actually coming from the steering box itself. Im not sure why this would whine but it is. If i apply some lock to the wheels the whine decreases |
