![]() | Home > Technical > Could the snow and ice knacker my clutch? |
Maverick Member Since: 08 Mar 2008 Location: Inverurie! Posts: 261 ![]() ![]() ![]() |
Just drove aprox. 2 miles with no clutch. Pedal travels half way down with no feeling then won't travel any further!
![]() Any other ideas? Cheers Ben Ben Rebuilt 1996 black/white Defender 90 300 TDi |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5112 ![]() ![]() ![]() |
Could it be water in the fluid thats frozen?
I have no other actual guess ![]() |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2489 ![]() ![]() ![]() |
water contamination, but rearlly unlikely. If you got water then the pipe would have broken. Strange.
The disc travels freely along the slippery input sfhaft and pushed by the bearing. Air in the system. Puma 110" SW ............................................................. Earth first. Other planets later |
RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363 ![]() ![]() |
Clutch master cylinder seals gone... vey common. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Full of fluid etc. Sounds like its the clutch release fork, the pivot wears through it and jams it. Thanks for the suggestions though!
![]() Rebuilt 1996 black/white Defender 90 300 TDi |
