Home > Puma (Tdci) > Temperature gauge
Coolcamper55
Scotland 2007 Defender 110 Puma 2.4 XS CSW Santorini Black
Temperature gauge
My gauge has suddenly stopped working.
It moves very slightly when ignition is switched on but does not rise with the engine temperature rising.
I knew the engine was warm as the heater produced hot air and strangely the Torque diagnostics registered 59 deg
I have checked the wiring diagrams and cannot find any reference to the gauge. Is there a fuse somewhere.
I have also checked the ws manual and it sheds no light.
Grateful for any help Tommy
110 XS TDCi
Post #496197 25th Jan 2016 3:22pm
andydef90
United Kingdom 2014 Defender 90 Puma 2.2 HT Corris Grey
have you checked the sensor on the block no lose wires
Post #496200 25th Jan 2016 3:29pm
dorsetsmith
if you take look on the link and down the page manuals and wiring manual for 2.4 puma
http://forums.lr4x4.com/index.php?showtopic=55983&page=4
if you can get use ecu diagnostic you work it out
Post #496225 25th Jan 2016 4:11pm
Martin
Site Admin
The gauge is controlled by CAN bus messages, are you getting the glow plug light and battery charge warning light coming on when you turn the key on?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #496248 25th Jan 2016 5:26pm
Coolcamper55
I have both the documents you speak of and have infact said so in my original post.
Thanks Tommy
110 XS TDCi
Post #496324 25th Jan 2016 8:47pm
Coolcamper55
I do indeed get all the indicator lights you mentioned and the fuel gauge also works.
Thanks for your support Tommy
110 XS TDCi
Post #496325 25th Jan 2016 8:49pm
Alexke
Belgium
Re: Temperature gauge
59c is slightly off blue.
I would check sensor or thermostat. Discovery 4 SDV6 Landmark
F31 320dA Msport xDrive
LR Defender 90SW TD4 Stornoway grey
320d E46
E70 X5 3.0d Sold!
FFRR TD6 - Sold
Post #496635 26th Jan 2016 3:39pm
Coolcamper55
New CHT arrived today. Will try and fit it tomorrow.
Thanks again for input Tommy
110 XS TDCi
Post #496652 26th Jan 2016 4:30pm
Coolcamper55
New CHT fitted. All back to normal.
Thanks for assistance Tommy
110 XS TDCi
Post #498713 31st Jan 2016 6:12pm
mcma1
What's the CHT?? Just noticed mine this morning is sitting just above the blue, and the blower temp is def down... Andy
2014 Fuji 110 SW LS3
https://www.defender2.net/forum/post751233.html#751233
2014 Corris 110 SW
http://www.defender2.net/forum/topic40056.html
My old Xtech 90 build..
http://www.defender2.net/forum/topic15681.html
LS3 V8 build...
http://www.defender2.net/forum/topic49051.html
Post #509194 29th Feb 2016 9:53am
Alexke
Belgium
Cylinder head temperature. Discovery 4 SDV6 Landmark
320d E46
E70 X5 3.0d Sold!
FFRR TD6 - Sold
Post #510218 3rd Mar 2016 8:52am
