Home > Td5 > Smoke Test DIY or NOT
chinnus
2001 Defender 90 Td5 ST Coniston Green
Any advice on how to do a smoke test DIY or can it only be done professionally... I think i may have an intercooler crack or leak as there is a lot of black soot around bottom left of the intercooler.
Not noticeable lack of power in the car just perhaps a bit sluggish... Has BAS Stage 2 tune and a serek motorsport cooler
Before i bite the bullet and get a new one I wanted to just check the air system for a leak... Its a td5 btw
thanks in advance
Post #495856 24th Jan 2016 6:24pm
LR90XS2011
spray it with soapy water and rev it up you will quickly know if you have a leak as it will bubble up DEFENDER 90 TDCI XS,
Post #495912 24th Jan 2016 8:16pm
shaggydog
Shouldn't be any black soot on that side of the inter cooler surely as it should just be fresh air?
Unless its after the EGR? Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #495956 24th Jan 2016 10:39pm
miker
You won't get soot, but if my memory serves me correctly there will be oil from the crankcase breather, feeds into the inlet just after the maf sensor.
Post #496162 25th Jan 2016 2:26pm
roel
Yes it will be oil. But with revving it you don't get that much pressure maybe half a bar. That might not be enough to open the crack. Roel
2003 90 Td5 (2009-now)
Post #496381 25th Jan 2016 10:24pm
