Home > My Defender > Here come the mods....! |
Butchers Boy Member Since: 10 Jan 2016 Location: Essex Posts: 426 |
Thanks Adam, I knew it had to be there somewhere 2010 Defender 90 HT The longer I live..... The better I was! |
24th Jan 2016 7:11pm |
All LED's now fitted and working They are so much brighter than the stock lights! A worthwhile mod IMHO 👍
Click image to enlarge Click image to enlarge Click image to enlarge 2010 Defender 90 HT The longer I live..... The better I was! |
24th Jan 2016 7:17pm |
Hi CY88,
I've wired them so they come on with the side lights I did ponder on fitting a DRL controller which turns the DRL's on as soon as you start the vehicle and then switches them off when you turn the side lights on - or so I'm lead to believe thats what they do? But like most boys with new toys I had already set aside this weekend to fit all my LED's and didn't want to wait for it all to arrive which would mean waiting another week to fit! I might look in to it and fit a DRL controler in the summer when the weather is a bit warmer for working outside being as I am a fair weather worker 2010 Defender 90 HT The longer I live..... The better I was! |
24th Jan 2016 8:15pm |
I've just ordered my next purchase to secure my new spare tyre and newly powder coated wheel (Tuesday this week!) on the back door. I've got to thank RRUK for this fine find! Thanks Adam... Where you go others are surly following !!
Boost Wheel Locking Kit for Land Rover Defender http://www.ebay.co.uk/itm/Boost-Wheel-Lock...Sw~bFWGUUw 2010 Defender 90 HT The longer I live..... The better I was! |
24th Jan 2016 8:26pm |
JAY BOY Member Since: 04 May 2010 Location: Not here Posts: 1706 |
Nice job that man
24th Jan 2016 8:31pm |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7875 |
Great work!
24th Jan 2016 8:41pm |
Snow cowl now fitted
Click image to enlarge Must thank GREENI I checked the drain bung in the inner wing for the heater intake and it was full of dirt! I could also see a water mark inside where water had been puddling! I cleared the bung out and run some fresh water through it and it all drained away nicely once cleared. With the new snow cowl now fitted it shouldn't block up again. Thanks for the headsup on that 2010 Defender 90 HT The longer I live..... The better I was! |
25th Jan 2016 6:50pm |
Enid_Puceflange Member Since: 25 Oct 2014 Location: edinburgh Posts: 1168 |
That's parked mighty close to the wall!! My confidence has been writing cheques that my abilities can't cash for years.
25th Jan 2016 9:51pm |
Yes almost as close as I park my Kombi !!
25th Jan 2016 10:10pm |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3696 |
^ Flippin heck I would have some rubber markers on the wall....
25th Jan 2016 10:13pm |
Very pleased with my new LED interior bulbs They are super bright and really crisp!
25th Jan 2016 10:18pm |
^ The cheapest mod I did on mine and brilliant
Did the rear one and front and makes it so much brighter Mine were these... I would like a delay on these to stay on a bit longer when turn engine off or open door... |
25th Jan 2016 10:21pm |
I fitted these front and back 36mm
http://www.ebay.co.uk/itm/271845715463?_tr...EBIDX%3AIT Brilliant can not recommend enough 2010 Defender 90 HT The longer I live..... The better I was! |
25th Jan 2016 11:12pm |
RRUK Site Supporter Member Since: 31 Mar 2010 Location: Leicestershire Posts: 2015 |
Did you poke your finger through that drain bung? I remember when I did my TD5 it felt a bit weird!
Mine was also blocked with mud and leaves. Another astonishing Land Rover design right there. A big catcher to funnel water and crud at your heater to break it! 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
25th Jan 2016 11:13pm |
