Home > Technical > drilling side windows
foxing
Wales
having a problem with my drivers side window it's cumming unstuck from the runners,tried a few different glues,so is it possible to drill the glass to fix some nuts and bolts through the clips?
atb paul
Post #495288 22nd Jan 2016 8:41pm
NO NO NO it will pop !!!
Post #495303 22nd Jan 2016 9:00pm
foxing
Wales
i thought so,any ideas what i can use to glue the glass to the runners?
atb paul
Post #495311 22nd Jan 2016 9:12pm
ickle
Sikaflex is your friend
Post #495314 22nd Jan 2016 9:13pm
I Like Old Skool
United Kingdom 1994 Defender 110 300 Tdi ST Coniston Green
Yes, you can drill a hole in the toughened glass. I did it to my first car, an old Lada I had back in the early 90s. Use a masonry bit and take it slowly (obviously not on hammer setting!). I suggest you wear safety goggles because about 10s after I finished the hole, while stood back admiring my handiwork some barsteward that must have been watching me work shot the glass. It exploded into a million fragments and if I had got any of that in my eyes it would have been nasty!
Post #495315 22nd Jan 2016 9:14pm
ickle
Shocked
Russian toughened glass must be a bit different then!
Post #495321 22nd Jan 2016 9:26pm
V8_Disco
1989 Defender 110 V8 Petrol SW Auto Bonatti Grey
New clips are about £3 ...
Post #495344 22nd Jan 2016 10:18pm
foxing
Wales
the clips are not the problem its getting them to stick to the glass
atb paul
Post #495348 22nd Jan 2016 10:27pm
V8_Disco
The bit on the glass? My white plastic clips looked fine but would not hold the edge of the glass new clips fixed it
Post #495362 22nd Jan 2016 11:01pm
Swac3
Ignore the below which was based on me having drilled a nice pair of holes in a 12mm glass fishtank,
HOWEVER :drilling toughened/tempered glass requires a dustpan and brush in addition to a drill Smile
If you're going to do it buy a glass drill, one for glass not one made of glass Smile
Don't go mad on the pressure let the drill do the work and keep it lubricated, if you're doing it outside lay the glass flat and trickle water over the cutting area, hose pipe will do, and be extra cautious at the end when you're about to go through in regards to the pressure/angle you have the drill bit.
As with most things like this where you wont have a spare easily to hand its more stressful than difficult.
A simple hole like this has to be easier than a 40mm hole cutter :-/
EDIT : havent used those bits that look like an arrow marketed as tile and glass, only the type that are more of a burr and diamond coated.
Gary 3 Landrovers
Post #495370 22nd Jan 2016 11:17pm
mk1collector
Araldite works well, the two part stuff. Ray
My build thread
Post #495379 22nd Jan 2016 11:27pm
I Like Old Skool
Swac3, I was only joking. You can't drill toughened glass, as I found out all those years ago. The amazing thing is I actually achieved my aim, if only momentarily. I can still remember it now, it was a hot day, I finished the hole, stood back and took a swig from a glass of coke and then, BANG! The glass exploded.
Post #495380 22nd Jan 2016 11:28pm
Swac3
+1 this.. glue is prolly more than sufficient despite my previous drilling post Smile
would have been a bit difficult to glue a 40mm hole into the 12mm glass that I did, but for your windows... glue. 3 Landrovers
Post #495384 22nd Jan 2016 11:32pm
foxing
Wales
just tried this and only lasted for about a week,will get new clips and take to an outo glass outlett and see if they can sort it out
atb paul
Post #495429 23rd Jan 2016 6:27am
mk1collector
I stuck some clips onto my new Windows 6ish months ago and mines still fine. Was the area completely clean and slightly scuffed? Ray
My build thread
Post #495488 23rd Jan 2016 12:37pm
