Home > Defender Celebration Series & Classic Works > Heritage Defender Extras
Page 8 of 10 <12345678910>
hw7905
Hong Kong
Grab handles look okay on Heritage?? Indeed the original Huey has them also.
Post #495204 22nd Jan 2016 4:33pm
flydive
Switzerland 2015 Defender 90 Puma 2.2 Heritage Edition SW Grasmere Green
Yes, I like them.
Is one of my planned mods
Post #495207 22nd Jan 2016 4:42pm
steve E
Wales
I like them tooo Very Happy
Post #495208 22nd Jan 2016 4:49pm
hw7905
Hong Kong
Oh. Thanks. They are really cheap on eBay. Either in Metallic Black or Matte Black. And they are made of aluminium and are so light Very Happy
Post #495224 22nd Jan 2016 5:52pm
RRUK
I used to have them on my Series 3 but never figured out what to use them as or for.... 2016 D4 HSE
1982 Series 3 SWB Petrol
Post #495232 22nd Jan 2016 6:13pm
hw7905
Hong Kong
I guess they are to protect the rear lamps, or work as buffer before something hits the rear bumper when the spare wheel is removed... Correct me if I am wrong pls.
Post #495233 22nd Jan 2016 6:16pm
hw7905
Hong Kong
Just wonder if the steel diesel badge will look nice on a Heritage:
http://www.ebay.com/itm/281891367564
I think the current yellow sticker looks a bit too modern. It will be great if the steel badge can be put on without drilling any holes, say using Pritr sticky tac??
Post #495719 24th Jan 2016 8:51am
Avion8
Australia 2015 Defender 90 Puma 2.2 Heritage Edition SW Grasmere Green
Thanks to YOLO I now have some nice FCX dashboard trim fittings.
The hardest part was swapping the opening lid on my glovebox. Not quite Grasmere green, but setting a green theme.. :mrgreen:
Post #496042 25th Jan 2016 8:21am
YOLO110
Australia
Blimey Nigel! That was quick!!! Thumbs Up
I have just got back! Needed to cool off in the 35C heat today
I think they look pretty cool actually... a much closer match than to Keswick! There is definitely an increasingly active 'Green Brigade' happening on here now... with 'Uncle Rog' leading the way!
Nice to meet up and to see all your other 'toys'... now get that lovely wheel fitted as well! Wink
Cheers, Pete. Smile YOLO... You Only Live Once...
Post #496061 25th Jan 2016 9:45am
Avion8
Thanks Pete,
I'm getting good at prizing those spring clips off the glove box lid. I'm very happy with the green, & don't think it has to be an exact match, just a nice contrast. Just need to find a spot in the shed now to store all the original removed hardware, where I can find it again!
I will work on the wheel one cool day, the last steering wheel I removed took 3 days off the old 80". Maybe the fact that it had been there 60+ years had something to do with it's stubbornness?
Cheers, Nigel
Post #496065 25th Jan 2016 9:57am
YOLO110
Australia
I found my Defender wheel came of with hardly any effort!
Loosen, but don't remove the nut (that was not even 'tab locked' in position), then a few wiggles and a firm pull had it easily off the splines against the nut. Make sure the previous wheel was dead straight, then just a matter of removing the nut and swapping the wheels over! Took me about 10 minutes.
This was compared with my Lotus that needed a wheel 'puller' despite having a big spring under the splines. If you removed the nut off them before removing the wheel, it was destined to end up in your chest at high speed!
Glad you like the trims mate! I think a matching green 'Huey' box is in order to keep all the stuff in! Thumbs Up YOLO... You Only Live Once...
Post #496072 25th Jan 2016 10:22am
integrale
New Zealand
Rear grab handles arrived today. Went to fit them......and there's a large (silver painted) bolt in the way stopping them fitting either side. Defender 90 Heritage.
Post #499776 3rd Feb 2016 1:43am
TonyF
Australia 2004 Defender 90 Td5 SW Bonatti Grey
yes, with rear seats and strengthening for seat belts I don't think it's possible without some modification.
Post #499778 3rd Feb 2016 2:11am
hw7905
Hong Kong
There was a post about this issue before:
http://www.defender2.net/forum/topic37340....ab+handles
Post #500327 4th Feb 2016 12:36pm
Martin
Site Admin
That's a "posh" copy of the original LR part:
Part number 502951 - about £3 from a LR dealer in the UK before discount
You could indeed use double-sided trim tape to fit it Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #500339 4th Feb 2016 12:57pm
