![]() | Home > Off Topic > Rivnut tool recommendation |
Replaced the rears with stainless nut and bolt (difficult,lol).I assume the same is not possible for the front??Also,really needed this weekend????Could be a good job for warmer weather. Pov.spec,ftw. 2006, 110,TD5.
Skeggy 90 Member Since: 07 Oct 2013 Location: Skeg Vegas Posts: 233 ![]() ![]() ![]() |
You don't need a tool, I just use a long bolt a few washers and a nut, works a treat, look on YouTube for how to do ir. The cheaper tools have a tendency of ripping the treads out if your not careful. 90 300 TDI SW (sold)
130 TD5 Utility (Foley SV) (sold) 110 TD5 Hardtop (sold) 110 TDCI Utility (sold) 1st Edition Range Rover Sport Supercharged Velar P380 HSE Discovery 1 V8 auto Puma 130 Double Cab (sold) R35 GTR Defender 110 300 TDI CSW (sold) 2010 110 XS Utility |
stricko Member Since: 30 Nov 2015 Location: East Sussex Posts: 120 ![]() ![]() |
Cheers Skeggy
I have had a look and will give that a go. Next question - any idea what size rivnut I should get ? --------------------------------------------------------------- |
6mm thread is for a 10mm headed bolt
8mm thread is for a 13 mm headed bolt There is a choice of aluminium or steel rivnuts, What size are the original mounting bolts, I would get the same if you can get away with it if not go one size bigger 90 300 TDI SW (sold) 130 TD5 Utility (Foley SV) (sold) 110 TD5 Hardtop (sold) 110 TDCI Utility (sold) 1st Edition Range Rover Sport Supercharged Velar P380 HSE Discovery 1 V8 auto Puma 130 Double Cab (sold) R35 GTR Defender 110 300 TDI CSW (sold) 2010 110 XS Utility |
cobs Member Since: 12 Jun 2008 Location: North Yorkshire Posts: 336 ![]() ![]() ![]() |
Possibly doesn't fit the 'cheap' description but the Memfast tool is very good
http://www.memfast.co.uk/cli/MEM001/PDF/RN...Review.pdf |
LRmud Member Since: 22 Oct 2014 Location: IV12 Highland Posts: 198 ![]() ![]() ![]() |
I just bought this from ebay and it works a treat. Very cheap AND effective.
http://www.ebay.co.uk/itm/121854739388 I've also got an M6, M8 and M10 - all good. Remember to put a dab of grease on the parts before use. ![]() 1989 Defender 90 Toyota Aygo & Honda FR-V |
