Home > Td5 > No heater air to the cab but heater working.
AJC
Hi folks. Up until today my td5's heater was fine.
Tonight I jumped in it and found the slider stick quite stiff to move from the 0 (off position) I wiggled it and it moved to 2 and there's nothing coming through to the cab.
I got out and you can hear the motor working but yet nothing coming through. I've checked the levers on the heater box and they move freely.
Any suggestions?
Thank you
Post #494544 20th Jan 2016 9:42pm
AJC
I have highlighted the cable and arms I've checked
Post #494546 20th Jan 2016 9:48pm
miker
I have no help to offer I'm afraid, but what's that attached to your bulkhead? Looks line a sound liner?
Post #494597 20th Jan 2016 11:34pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
Is it drawing air through the intake? 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #494608 21st Jan 2016 12:08am
AJC
It's not mine, just a picture i 'googled'
Post #494628 21st Jan 2016 7:43am
AJC
Hi, yes, if i put my head to the wing air intake there's a lot of noise as if its sucking in lot of air.
I'm that frustrated by it i'm going to skive off work for 1/2 hour once it's daylight and go investigate, i think it could be a stuck lever.
Whilst i think i'm fairly mechanically minded, i've never had a Td5 and not had a defender for 7 years and that never had any issues.
Give me a mk3 escort and i can identify them part for part
Post #494629 21st Jan 2016 7:49am
calum
United Kingdom 2004 Defender 90 Td5 SW Zambezi Silver
Remove the wing top grille and check it's not full of leaves or organic matter and water? Also check that the drain hole in there is clear at the same time.
Calum
Post #495702 24th Jan 2016 12:50am
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
The first thing I would check is that you have water in the radiator. Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #495810 24th Jan 2016 2:54pm
