Home > Tdi > Drivetrain locking up/clunking
Weston18
England 1999 Defender 110 300 Tdi DCPU Tonga Green
Hi all,
Looking for a bit of advice, I'm normally quite handy at diagnosing faults on vehicles and this being my third truck I've had a fair bit of practise!
About a month ago I noticed a clunking from the drive train after accelerating out of a 2nd gear bend, it sounded a little like a knackered uj. I checked them on the vehicle and didn't see anything out of the ordinary, fast forward a few days and I was in 5th gear travelling at 40-50 ish and then with no warning it felt like the drivetrain locked momentarily and there was a bang. I pulled over at the next opportunity and checked underneath, no signs of anything failed. I drove it home and it was fine, drove with no noises. Few days later I pull off from the traffics lights and another loud bang and a drive line seizure for a moment.
I then decided to take it off the road to look into the issue, took both props off and they look and feel fine with no play or tight spots. I then ran the engine and watched the transfer box outputs spinning and the rear output shaft was bent. Something that I'd not heard of before. Changed the transferbox for a discovery unit and then decided to change the differential oils and they were both clean with no sparkle.
This leaves me where I am now, it's still seems to be doing it. Once again it's very occasional, and it doesn't seem as severe but bad enough.
Any suggestions as to what it may be are welcome. I'm going grey at serious pace at the minute.
Also unsure as to how I would bend the output shaft?
Post #494555 20th Jan 2016 10:09pm
Retroanaconda
Diff failing internally and locking up sporadically perhaps?
Rear diff I'd easy to pop out for a look if it's a 90 or later 110, or the cover plate can be removed even more easily if it's an earlier 110.
Post #494557 20th Jan 2016 10:17pm
Weston18
I thought that aswel hence changing the fluids, I know it's no comprehensive but there was no metal in the oil at all but I will try and take the diff out on my next days off.
It's a post 2002 110 rear axle so just have to pull it out.
Post #494570 20th Jan 2016 10:29pm
Weston18
Also to add too the issues its throwing at me it didn't want to start this morning. Flat battery, need to look into that too.
Post #494751 21st Jan 2016 1:22pm
Handbrake snatching? Can make all manner of destructive noises.
Post #494787 21st Jan 2016 2:31pm
Thon
Front axle cv joint disintegrating?
Post #494795 21st Jan 2016 2:58pm
g-mack
stuck in diff lock ? if it is you would get transmission wind up, which i think can cause them symptoms, My 109 thread
my youtube channel
Post #494825 21st Jan 2016 4:18pm
Weston18
Thanks for all the replies guys.
The handbrake is fairly loose and can't see how it would snatch being as it is but good thinking.
Cv is also something still to check on the list but I'm leaving that down the list as it seems to feel central when locking up and not pull to one side. Which I would imagine it would if it was on one corner? Also I've had no issues when turning tight which when I've smashed one before I certainly got.
It's not in diff lock and I checked that when fitting the new transfer box. The old one did have a lot of play when locked between the two output shafts.
Post #494954 21st Jan 2016 10:23pm
Weston18
Post #494961 21st Jan 2016 10:45pm
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
Some years ago I had a similar banging from the rear of a 300tdi 90 until one day the rear nearside locked up at 70 mph. which nearly took me off the road. It felt as though the rear brakes had locked on . Called a breakdown company who sent recovery driver who happened to be a Land Rover fanatic who thought it was the handbrake that had come on, that was not the case so tried to pull the 90 onto the vehicle and both rear wheels were locked. After disconnecting the prop shaft and find that both wheels were locked still it was off to my local independent who found that both rear stub axels seals had failed allowing road silt into the bearing which had failed and eventualy they seized . Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #495819 24th Jan 2016 3:40pm
Weston18
Update on the situation
I drained my gearbox to see what condition the oil was in. It still had plenty in and wasn't in too bad condition there were some small filings on the drain plug but nothing of any size.
Here's the evidence...........
I continued to look round the vehicle and found a front wheel bearing that was graunching. It looked fine but sounded and felt terrible.
I fitted a new one and it's not done it yet so touch wood it's sorted but still taking it steady.
Work car park shot too.
Post #497955 29th Jan 2016 6:54pm
steventheplumber
England 1987 Defender 90 200 Tdi HT Keswick Green
Nice landy hope it's running OK now
Post #512850 10th Mar 2016 5:34pm
shaggydog
That is a really nice truck Thumbs Up Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #513018 10th Mar 2016 11:15pm
Weston18
I miss my truck, I've not driven her for about a month and she's sat on my drive waiting for some work ready for its mot. The best bit is that the mrs is begging me to fix it. Keeper.
Wading isn't quite the same in a micra...................
Post #513150 11th Mar 2016 12:11pm
yostumpy
''you can , with a Nissan !''
Post #516005 19th Mar 2016 6:46pm
