![]() | Home > In Car Electronics > 1997 TDI300 110 OBD connector |
| theorangebandit Member Since: 03 Jun 2013 Location: Stowmarket Posts: 862 |
300tdi doesn't have OBD socket. Nor does it have an ECU. Functions old school. Bucket of fuel plus lung full of air equals combustion. 👍
| g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967
the last ones 97/98 did move to some kind of electric trickery though I'm not sure what it was for. mine is 12v to the solenoid to keep it going version!!
my youtube channel |
| itolond Member Since: 16 Jan 2016 Location: Singapore Posts: 193
dang, that makes life harder
are there any aftermarket senders that can output OBDII type of data? |
Not sure what your goal is, what are your trying to achieve ? Perhaps there is already, or even simply, an alternatively simpler option.
The later ones came with electronic EGR module. Most people removed these haha 😆 |
| grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802
If you're after comprehensive engine data readouts you may be better going for a madman gauge
I have seen plenty of aftermarket instrumentation Edo digital which use OBD type connectors. So in lieu of obd is have senders supply same data which provides more choices
Just after the basic, oil, water speed rpm and dash information warning lights etc |
I do believe the madman brand have a screen which you can plug into all the necessary senders and sensors to give information on one screen. For me though I would spend half that cash on some very nice dialls for each feature. You can get dials for all types of sensing you can even have a matching out side temperature dial it you like
Agreed, evaluating at the mo
is there a link for Madman stuff> |
| Cupboard Member Since: 21 Mar 2014 Location: Suffolk Posts: 2971
http://www.4x4overlander.com/?s=madman&post_type=product
They're site sponsors and usually pretty helpful |
| GS1512 Member Since: 10 Oct 2025 Location: Glenshee Posts: 1
Our 1998 110 has an OBD socket, IIRC it was fitted only for vehicles with the factory-fitted alarm/imobilser. We bought the car new so can confirm it's original. Hope this (very late) response helps anyone. |
| julian Member Since: 17 Feb 2017 Location: Devon Posts: 204
Oil - third party sandwich plate, sender and gauge Water -included as standard Rpm - £20 eBay counter connected to w terminal |
