|  | Home > Technical > Auto flexplate broken |
| BigRuss Member Since: 15 May 2010 Location: Norfolk Posts: 2785      | Sounds like you need to determine if the plate failed due to the torque being put through it or just fatigue over years of use and abuse. Russell
 2011MY 110 XS USW Black | ||
|  20th Jan 2016 9:01am |
| Alex1976 Member Since: 23 Jan 2013 Location: Buckingham Posts: 596    | The flexplate was a used part taken from an 86K Disco so it could well have been fatigued before I even used it in the Defender.
 Thanks | ||
|  20th Jan 2016 9:22am |
| BigRuss Member Since: 15 May 2010 Location: Norfolk Posts: 2785      | Ok, so roughly how many miles has it done since being fitted and since it has had to handle more torque? Russell
|  20th Jan 2016 11:45am |
| Supacat Member Since: 16 Oct 2012 Location: West Yorkshire Posts: 11018      | The MD one is not that more expensive than genuine but I'm unclear about what makes it upgraded - why don't sellers put the details on the website?
 Interesting that Ashcroft state: "These are prone to cracking and it's good practice to change it when changing the autobox." I word with Ashcroft as to why they don't offer an upgraded part might help you decide whether it's a good thing or may actually just transfer the issue to a more expensive part? | ||
|  20th Jan 2016 11:50am |
| Alex1976 Member Since: 23 Jan 2013 Location: Buckingham Posts: 596    | Its covered about 20K since fitting.
 I don't have any dyno figures for how much torque the engine is now producing, but with the mods it has had done it must be close to a 2.8TGV and I note the Ashcroft site advises using an uprated autobox to handle the torque from a TGV (although no mention of uprated flexplate). | ||
|  20th Jan 2016 11:53am |
| Alex1976 Member Since: 23 Jan 2013 Location: Buckingham Posts: 596    | Supacat - I agree it is very annoying when sellers don't give technical specs/info when selling technical products, especially when they are claiming it to be technically superior product.
 I presume the uprated version is similar to Ashcrofts TD5 uprated flexplate - made from thicker, stronger material. I think I need to have a chat with the guru of all things Landrover gearbox related - Dave Ashcroft. As you said, it may be the flexplate is a designed failure point in order to protect more expensive parts. | ||
|  20th Jan 2016 11:59am |
| L90Andy Member Since: 29 May 2014 Location: Stratford-Upon-Avon Posts: 728      | Count me in for helping to fit whatever you decide on - I owe you a few spannering favours! | ||
|  20th Jan 2016 12:13pm |
| Alex1976 Member Since: 23 Jan 2013 Location: Buckingham Posts: 596    | Thank you!  I will take you up on that offer as I wasn't looking forward to wrestling with a Tbox and autobox on my own.    | ||
|  20th Jan 2016 12:16pm |
| ashtrans Site Sponsor Member Since: 08 Nov 2008 Location: Harpenden Posts: 264    | Hi,
 Our 300 tdi flexplate is made from a better material than genuine. We use a CS80 Spring steel, I don't think I have seen one of these fail and we use then for the 300 tdi, TD5 and Pumas Dave Dave | ||
|  20th Jan 2016 10:19pm |
| Alex1976 Member Since: 23 Jan 2013 Location: Buckingham Posts: 596    | Thanks for the info Dave.  Very reassuring to know the new flex plates are stronger.  I placed an order with you earlier today for a new one.
 Cheers, Alex | ||
|  20th Jan 2016 10:28pm |
| Alex1976 Member Since: 23 Jan 2013 Location: Buckingham Posts: 596    | Well, I took out the gearbox yesterday and found that the original diagnosis was correct.  The flexplate centre has been ripped out.  It is a perfect circle around the centre.
   Click image to enlarge | ||
|  31st Jan 2016 10:54am |
| Supacat Member Since: 16 Oct 2012 Location: West Yorkshire Posts: 11018      | That's impressive! | ||
|  31st Jan 2016 11:56am |
| landyman37 Member Since: 22 Jan 2012 Location: west midlands Posts: 156  | Alex this might be a bit late did it have a spacing ring on it (like a type of washer) or did the bolts go straight through the plate no spacing ring | ||
|  20th Feb 2016 1:34pm |
| Alex1976 Member Since: 23 Jan 2013 Location: Buckingham Posts: 596    | Yes - there was a couple of spacer rings. A thick ring that sat between the crank and the flexplate and a thin one between the flexplate and the crank bolts. | ||
|  20th Feb 2016 1:38pm |
| Posting Rules
