Home > Td5 > NO Coolant damage? Where is the Engine Temperatures Sensor?
kweese
Canada 1999 Defender 110 Td5 SW Belize Green
Hi. I was on the highway yesterday and my coolant drained out through the same Welch (frost) Plug. I didnt realize until i saw the temp just shoot up for a second. I stopped the car and realized that there was no coolant. I drove another 20 km home, while watching the temperature guage. Does the temperature gauge only measure coolant temperature???
Post #493964 19th Jan 2016 8:28am
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
Most do yes, in this situation I would of topped up the coolant with water to drive it home. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #493990 19th Jan 2016 9:44am
Not sure about the TD5, but historically temperature senders have relied upon being in contact with the coolant in order to provide a reading. If there is no coolant, they will read low regardless of the engine temperature.
I have to say that there is no way I would drive a TD5 (or indeed any other diesel engine, or any other modern engine) 20km with no coolant since I think the risk of catastrophic engine damage is extreme.
Many years ago I owned a 1966 Triumph 2000 Mk1 with a 6-cylinder petrol engine (my first car, in fact). On one occasion that lost its coolant, and it was an interesting "learning experience" for a new-ish driver. At no time did the temperature gauge show the engine overheating, all that happened was the car became more and more sluggish, a hot smell developed, and eventually the engine stalled as the pistons seized in the bores. Amazingly once it had cooled down, I had fixed the leak and replaceed the coolant, it ran as well as ever with no sign of any damage!
I would not however knowingly ever subject a diesel engine to similar treatment since diesels have always been more susceptible to damage through overheating than perol engines.
Fingers crossed that your engine is OK!
Post #494004 19th Jan 2016 10:29am
ROBBONTHEROCK
Scotland 2007 Defender 110 Puma 2.4 XS CSW Firenze Red
Diesels run hotter generally.
The OP might have gotten away with it, if the ambient temp is low enough, I note he is in Canada, so -25deg C with -50 wind-chill would definitely help in the engine cooling department.
I think TD5's run cooler anyway don't they, i.e. it takes ages to warm up?
Also note that the coolant would have drained to that level, so wouldn't have been completely empty.
Always a chance and well, at this stage what have you got to lose?!
Andy
Post #494042 19th Jan 2016 12:51pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
only thing to do is to replace plug, refill, bleed and see what if any thing is up?
Good luck 2020 range Rover Mk IV Autobiography PHEV
2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #494077 19th Jan 2016 3:04pm
4RF RDS
only thing to do is to replace plug, refill, bleed and see what if any thing is up? (Edit...not sure this posted twice???? Sorry).
1967 MGB GT
Post #494079 19th Jan 2016 3:05pm
dorsetsmith
Good luck
37D2260L one on the head at the back and one short block alt side
LCM100150 one on stort block alt side
ERR6674 one on the head at the front
Post #494091 19th Jan 2016 3:51pm
