![]() | Home > My Defender > My new (to me) Defender 90 Puma |
| BossHog Member Since: 28 Jun 2013 Location: Fylde Coast Posts: 185
Have you fitted the Dirt D Fenders on the front and back or just the fronts ?
| RRUK Site Supporter Member Since: 31 Mar 2010 Location: Leicestershire Posts: 2038
Just the fronts. 2016 D4 HSE
1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
| Mickysham Member Since: 26 Jul 2015 Location: Coleraine Posts: 2
I love this post! Read every page and so much inspiration for my own..
A quick internet purchase.
I emailed MUD before xmas about their sun visor mirror to see if they did it in black too, so it matched my nice black headlining and sun visors, and now they do! So, ordered one for the passenger side and a couple of their curry hooks to put in the rear to hang coats on when out shooting. 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
| Sadi Member Since: 23 Jul 2015 Location: Windhoek Posts: 334
Hi RRUK, The Dirt D-fenders come with a short piece of foam with an adhesive backing. What exactly is this for please - if you used it during your installation ? Thank you. |
The single foam strip is so that you can plug any gaps due to land rover build tolerance. I found I used a bit in each corner. 2016 D4 HSE
Thank you !!!
More presents in the post.
The MUD sun visor mirror arrived, along with the 2 curry hooks which I shall use as coat hooks. The mirror looks better than on the MUD site as the grained finish looks better than their photos, and the entire back is covered in a sticky pad. These are designed for the original sun visors, I'm not sure if they would work on the black alcantara ones (do they have mirrors in them already?) The curry hooks just need two small holes drilled into the plastic trim to fix, the lower is a positioning peg and the upper for a self tapper. Easiest jobs ever. Click image to enlarge Click image to enlarge 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
Was in Tesco today in the motoring section and saw this little gizmo.
Basically it must be a bag of Silica Gel crystals or similar. A coloured indicator on the outside shows you when it is saturated and you recharge it by heating on a radiator or in the microwave. For a car like a Defender which can easily get damp inside with drips and leaks, this seemed a no brainer to me so I have installed one in the cab. It was £7.50. Pic to follow. 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
| nosnibod Member Since: 15 Aug 2007 Location: West Midlands Posts: 371
Those Mudstuff mirrors do work with the black headlining visors
These new ones look rather better made than previous versions from Mudstuff, which appeared to be held together with hot glue and I had one come apart. The new ones appear to have a proper retainer for the mirror inside the plastic frame - very nicely made. Dave Green Goddess - 1998 Defender 110 300tdi |
| Ryderoo Member Since: 28 Aug 2015 Location: South Oxfordshire Posts: 1666
Looks good, I would be interested to hear how you get on with this product RRUK. Also I'm thinking of getting the Mud vanity mirror for the Missus for Valentines day I can explain it to you, but I can't understand it for you 1990 110 TD5 county, my first Land Rover - gone 2012 Discovery 4 XS SDV6 - gone 2014 Discovery 4 XS SDV6 - gone 2015 Evoque SD4 dynamic - Wife’s - gone 2015 Urban Truck 90 XS Santorini Black Hard Top - Reluctantly gone 2020 Discovery 5 Eiger Grey 3.0 SE - gone March 24 2021 Defender S D250 Santorini Black 110 HT - gone March 24 2023 Evoque P300e SE wife’s current vehicle |
A couple of tweaks.
Fitted the MUD hooks in the back on each side for hanging my shooting coat. Simple to fit. The positioning peg on it needs a 4mm hole to seat it, then I used a 2.5mm drill for the pilot hole and the s/s self tapper screw in each. I positioned them near the metal hanging support bracket for the side trim for extra strength. Next I measured and cut a piece of the windscreen sun film to help with the blinding sun rays that get between the rear view mirror and the sun visors when it's low in the sky. Fitting is simple, pull the film apart to reveal the tinted side and coat in soapy liquid from a spray gun, plus on the glass. Then slip on to its position and spray the top surface. This lubes the squeegee as you work out the liquid and air bubbles till it's flat and sealed. Then dry and leave taking care not to move it. Be gentle. It may not look very fancy but it's functional and it works. If you look at the pics you can also see the MUD vanity mirror in place. Click image to enlarge Click image to enlarge Click image to enlarge 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
| Butchers Boy Member Since: 10 Jan 2016 Location: Essex Posts: 426
Looking really nice Adam
The longer I live..... The better I was! |
