Home > Maintenance & Modifications > Connection for Tuning Box
Petronius4
United Kingdom 2015 Defender 90 Puma 2.2 SW Keswick Green
Afternoon all.
I have a Speedhawk Tuning box that I want to fit to my 90 TDCi (2015MY). Having just spent 30mins in the freezing cold having a hunt round its not immediately obvious where the box plugs in so I thought I'd save myself some hyperthermia time and ask.
Anyone have a picture of where the connection is?
Thanks -------------------------------
πŸ‘²πŸ» 1986 ex-Military 90 NAD 2.5 Soft Top. Sold
πŸ‡¬πŸ‡§ 2015 Defender 90 - Ripon Landrover Heritage 006
Post #493723 18th Jan 2016 4:59pm
ericvv
Off Topic You have one of the Ripon Heritage editions? One like in below pictures? Probably the nicest dealer conversion that I have ever seen, congratulations.
But, thought they only made 5 in total, and you say you have number 006. How many did they make in the end in total then? I remember their plan at the time was 2x90HT, 2x90SW, 1x110SW.
Eric
 You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #493726 18th Jan 2016 5:15pm
Open the panel below the steering wheel, 2x plastic flat head screws and you will find it
Post #493753 18th Jan 2016 6:35pm
Petronius4
[quote="ericvv"]Off Topic You have one of the Ripon Heritage editions? One like in below pictures? Probably the nicest dealer conversion that I have ever seen, congratulations.
Eric
Eric, you're correct the original pan was to only make 5 and thats what I thought until I picked it up and they had put 006 on the back! There is someone from Ripon on here so maybe he'll know the quantity they finally produced. (i'm secretly hoping its only six...)
This is mine...
Post #493764 18th Jan 2016 6:58pm
Petronius4
Bpman: Thanks. Yes I've found that but the Speedhawk connects under the bonnet somewhere onto they injector loom - or leastways did when I had the box fitted to my Range Rover. Any ideas? -------------------------------
Post #493765 18th Jan 2016 7:01pm
Petronius4
Bump -------------------------------
Post #493911 18th Jan 2016 11:13pm
Sadi
Namibia 2016 Defender 110 Puma 2.2 Heritage Edition SW Grasmere Green
Tuning box..
Tuning boxes normally connect to the common rail.
If previously used on a RR - would it work on the Puma?
If the company still exists - they should be able to provide the necessary info.
Hope this helps.
Post #493941 19th Jan 2016 5:50am
Cheshire110
Yep they plug into the common rail, couldn't describe exactly where it is though but have done it.
However, it might not be what you want to hear, but the advice from most on here would be to steer well clear of these things.
They are NOT a remap, but instead just a resistor which tricks the car into thinking it is putting less fuel in than it is (hence plugging straight into the common rail, not the ECU).
There are stories galore of faults and failures caused by these things, admittedly as well as some stories where everything is fine. Proceed with caution. Cheers, David
Post #493984 19th Jan 2016 10:21am
roel
I tried to find some info about this box. I didn't find much except that it manipulates airflow and fuelpressure data.
I don't like that. I have however also a tuning box a psi power box for my td5. This works different it send more fuel in the cylinder by keeping the injector longer open. I think that is better.
A real remap can be better but I can switch it off and normally don't use it on-road only off-road. Roel
2003 90 Td5 (2009-now)
Post #494165 19th Jan 2016 9:22pm
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
Tuning boxes are not good the ecu on a -2.2 needs a proper calabration not. Plug in box it will do more harm than good
All that thing will do is shirt more diesel in and pronounce any underlying problems the original calibration llready has
Steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #494181 19th Jan 2016 9:48pm
Happyoldgit
If you want it tuned get a proper a remap. Steve.
http://forums.lr4x4.com
Post #494394 20th Jan 2016 1:40pm
