![]() | Home > Td5 > ACE or no ACE? ALTERNATOR BELT |
kweese Member Since: 28 Apr 2015 Location: Van Posts: 62 ![]() ![]() ![]() |
Hi. My belt is squeeking now. if I replace, I'm not sure which belt to buy.
1999 Defender TD5. No Air Con. Help Please Also, should I replace anything else with the belt? Tensioner? |
Disco_Mikey Member Since: 16 Nov 2014 Location: Dundee Posts: 532 ![]() ![]() ![]() |
PQS101490 I believe. Defender was never fitted with ACE
ROBBONTHEROCK Member Since: 23 Jun 2014 Location: Aberdeenshire Posts: 637 ![]() ![]() ![]() |
While the belts off, I suggest you have a play with the idler pulleys, if they feel notchy then replace them, quite cheap and simple enough job.
My engine sounded quite rough sounding (metallic), i got quite worried for a while until i removed the belt and ran the engine - noise disappeared, i then found that both of my pulleys (the in the AC and ACE positions) were notch, replaced them with genuine LR parts. Cheers Andy |
Which part numbers are they? (the pulleys)
THe reason I ask is because i'm in Canada and Postage is usually the same price as the parts! So it is better I make one order instead of several. |
jomara Member Since: 26 Oct 2009 Location: Lanarkshire Posts: 1790 ![]() ![]() ![]() |
Hi Kweese,
Have you tried LR Imports in Calgary, they seem to have a large selection of parts and accessories http://www.lr-imports.com/contact-us/ ![]() 1971 Bowler Tomcat 88 4.2 V8 Auto 2022 110 D250 XS Edition - GONE 2024 110 D250 X-Dynamic HSE |
Hi,
I dug into my emails and found this:- 1 x Idler Td5 Less ACE (Genuine) ERR6658LR (ERR6658LR) = £38.33 1 x Idler Td5 Less Air Con (Genuine) ERR6493LR (ERR6493LR) = £25.00 1 x Tensioner Fan Belt Td5 (Genuine) ERR6951G (ERR6951LR) = £35.00 All this was from island 4x4. I went the whole hog and bought all three, I didn't fit the tensioner idler (not yet), probably will as soon as I have a reason to get into that area of the car again. Above is correct for:- Defender 110, 2001 TD5, with no AC and no ACE; Cheers Andy |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 993 ![]() ![]() ![]() |
kweese, give Peter at 3 Brothers Classic Land Rovers in Ontario a call. They bring in a container weekly and offer excellent service and pricing. They'll treat you right if you are not doing your own importing. http://3brothersclassicrovers.com
Cheers 2020 range Rover Mk IV Autobiography PHEV 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
