![]() | Home > Td5 > TD5 poor fuel economy |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2967 ![]() ![]() |
Fuel leak
fuel regulator driver side back of engine
http://www.discovery2.co.uk/Fpr.html |
On the bell auto website it shows you how to check the maf with a multimeter (just to rule it out again) as four in a year could mean there's a problem somewhere else that's killing the maf? Ray
grumpy old git Member Since: 16 Nov 2013 Location: United Kingdom Posts: 153 ![]() ![]() |
^^^^ Do you have a K&N fitted?
Jago Member Since: 15 Jan 2016 Location: Somerset Posts: 7 ![]() ![]() |
I have a piper cross filter similar to k&n. What to check on fuel regulater?
at the back engine driver side if fuel regulator is leaking smell of fuel and fuel run down over starter motor and drips off bell housing
Hufflepuff Member Since: 25 Oct 2014 Location: Hampshire Posts: 727 ![]() ![]() ![]() |
Hmm so I might have a similar issue. Car has dropped a couple of mpg no matter how gently I drive it - and its started leaving a drip where I park it, but is using no oil.
The problem is the undertray is preventing me from seeing where its coming from - and its not dripping to the point where I can actually sit and watch it. Its difficult to get my hand down under the regulator to see if fuel is coming out - but can you lose a significant amount of fuel out of it, or is it just likely to be a mild drip which isn't too critical in the short term? Would have liked to have limped through to warmer and drier conditions to make a more thorough assessment. |
ajps72 Member Since: 08 Jan 2012 Location: Lima Peru Posts: 105 ![]() ![]() |
Not sure if the Piper cross filter uses oil like the K&N, but that oil will kill your MAF very fast Augusto Defender 110 TD5 2001 Discovery 4 TDV6 |
hopeydaze Member Since: 11 May 2011 Location: Bath Posts: 30 ![]() ![]() ![]() |
Also worth checking the fuel filter on the outside of the chassis just behind the drivers door. Mine leaked pretty badly at one time
Have looked on the bell auto site and it said check maff reading on pin 2 with multimeter which I have done but have no reading but on pin 3 I get 1.4-1.5 so thinking maff might be at fault has anyone got any other ideas before I spend another £60?? Thanks
Have you checked in the red ecu plug to see if there is oil in there? Ray
Yes replaced a couple of months ago by landrover dealer
johnszs Member Since: 16 Aug 2010 Location: Hereford Posts: 459 ![]() ![]() ![]() |
I would disconnect the loom going to the maf and try that for a week or so and see if theres an improvement 2004 TD5 Defender 90 xs station wagon
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1789 ![]() ![]() ![]() |
If you look at the FPR (rear right side of the block as sat in the drivers seat) then you'll see a suspicious clean/dieselly streak below it! Or if it was as bad as mine, when the engine is running you'll see the hose along the side of the block squirting diesel everywhere. |
