Home > Td5 > Td5 alarm keeps going off
Millsy94
England 2003 Defender 90 Td5 PU Aintree Green
Hi all recently bought a 53plate td5 90 station wagon with alarm and central locking I washed it this morning but only with a sponge. Ever since the alarm keeps going off about once or twice an hour and when it goes off it unlocks or vice versa. Please help I've not long had to but this one as my other one got stolen so really need it to lock and behave cheers ed
Post #493016 16th Jan 2016 7:21pm
dorsetsmith
make shore door interior light switch are dry and in good working order
do you have battery backed alarm sounder power connector to it ok
also how is your spider collection Laughing set my alarm off sometimes
Post #493027 16th Jan 2016 8:10pm
Tiger
Take the speaker out of the drivers footwell.
Shine torch into dash cavity
Look for water near green box
Post #493029 16th Jan 2016 8:13pm
Millsy94
Ok will check all door switches tomorrow and green box. What is the battery backed alarm sounder?? Cheers for quick responses
Post #493120 16th Jan 2016 11:43pm
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
I had the same thing a while ago, tended to go off at 3am!
I bought a set of door contact recess switches for a few quid and fitted them, also unplug the movement sensor above the driver, more hassle than it's worth.
http://www.ebay.co.uk/ulk/itm/221957372514
Post #493157 17th Jan 2016 6:37am
Millsy94
Ah will try unplugging the sensor. It doesn't seem to play up if you lol with the key if that makes a difference
Post #493185 17th Jan 2016 10:16am
barbel jim
i'm pretty sure locking with the key disarms the interior motion sensor, as that way it donsn't go off when you lock the dogs/ kids in Thumbs Up Might have found youre offending item Whistle
Post #493193 17th Jan 2016 11:03am
Laurie
It's water in the door switches. Spray them with WD40 with the tube on the can so you get good penetration round the button. Lasts for years.
If that doesn't work, look for a fly or moth inside the cab. Rolling Eyes
Post #493238 17th Jan 2016 1:10pm
Tiger
I don't think this is true and is a common misconception.
I'll double check though
Post #493355 17th Jan 2016 7:07pm
Tiger
Yep as suspected locking with key is identical as locking with plip
See here
http://www.nanocom-diagnostics.com/uploads...0Guide.pdf
You could verify this by locking with drivers window down via key wait 60secs and wave arm around inside.
Thumbs Up
Post #493356 17th Jan 2016 7:13pm
mk1collector
On mine it works Shocked if you lock with the key (which I occasionally do if the dog is in the car) the motion sensor doesn't set so the dog doesn't set the alarm off. I have also checked the motion sensor works with the alarm fob (just in case) and the alarm went off with me waving my arm inside. Ray
My build thread
Post #493362 17th Jan 2016 7:27pm
Tiger
Ray,
Your alarm doesn't go off because you have a Lab & 110
This is just a combination of well behaved naturally lazy dog that lies down a long way from a crap sensor
Go test it now by locking with key with driver window down.
Ultrasonics should arm
Whistle
Post #493378 17th Jan 2016 7:54pm
Justtellme
Canada 2003 Defender 110 Td5 SW Oslo Blue
My manual says to lock the car with the remote while one of the doors is open. Then close the door and voila the car is locked and alarmed but with the interior motion sensor now disabled.
Thing is I have a stock TD5 2003 110 with alarm, no battery back up sounder fitted and no motion sensor fitted in the car, but everything else. Is this a normal setup? I bought mine second hand from Germany.
Patrick
Post #493426 17th Jan 2016 9:25pm
barbel jim
It works on mine Mr. Green
Post #493450 17th Jan 2016 10:01pm
mk1collector
Tiger wrote:
Ray,
Whistle
Rolling with laughter it also works if I leave the kids in the car while I nip into the shops, they sit in the middle row and they are never still Rolling with laughter Ray
My build thread
Post #493463 17th Jan 2016 10:17pm
