Home > Maintenance & Modifications > Plastic headlight cover/protector
jbk
United Kingdom 2016 Defender 90 Puma 2.2 HT Santorini Black
Hi All, I've seen some perspex like headlight protector plate on a few defenders and quite like the idea to look after my just purchased speaker LED headlights, but I cannot find the product retailed anywhere. The product I've seen and am looking for was kind of like in the attached picture, though not so large, rather only covering the actual headlight. Any ideas on source, advice, experience with these?
Thanks.
Post #493066 16th Jan 2016 9:28pm
VeeTee
Netherlands
Land Rover Part Number: STC7561. Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #493071 16th Jan 2016 9:40pm
dorsetsmith
Post #493082 16th Jan 2016 9:57pm
mk1collector
I've got some on mine because with having led headlights that run cold, snow can build up in winter and I though the covers would stop this happening. Two things I have found are, muck and water can get down behind them which makes them look terrible so I put a thin line of closed cell foam around the edge to stop anything getting down the back but when it gets cold now the covers fog up which is annoying. This shouldn't be a problem in summer but it's not so good in winter Rolling Eyes
 Ray
My build thread
Post #493214 17th Jan 2016 11:59am
They will protect but the inside face will also get dirty fairly regularly and so to clean you will need to factor in taking them off and putting them back on again.
Post #493215 17th Jan 2016 12:03pm
Sadi
Namibia 2016 Defender 110 Puma 2.2 Heritage Edition SW Grasmere Green
3M VPS or a clear window "smash & grab" film on the outer lens will also provide excellent protection - without issues of removing and cleaning.
Post #493226 17th Jan 2016 12:37pm
Retroanaconda
Is it really a problem that needs to be solved?
I can't say I've heard of large numbers of Defenders suffering with smashed headlamps driving around the UK, or even further afield. Unless you're bashing through jungles or following trucks on gravel roads for hundreds of miles are they really at risk?
The plastic lamps such as the Wipac Crystals or the LED offerings are probably more resistant to smashing than the glass ones anyway.
Post #493261 17th Jan 2016 2:28pm
mk1collector
As said above, my reason for having them is to keep snow off the lights in winter Thumbs Up Ray
My build thread
Post #493266 17th Jan 2016 2:49pm
jbk
Thanks for the info guys, nice looks good 'Mk1collector'.
Post #493328 17th Jan 2016 5:50pm
grafty99
I've had a headlight smash before I changed to led. The stone was still inside, it happened within a 10mile stretch of my home Sad 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #493338 17th Jan 2016 6:14pm
mk1collector
Thumbs Up Ray
My build thread
Post #493359 17th Jan 2016 7:20pm
JAY BOY
Wales
James
Have you got your car yet Thumbs Up
Post #499374 1st Feb 2016 11:24pm
